Old 06-13-2007, 08:41 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Who makes camber bolts?
I need some.
Old 06-14-2007, 03:57 PM   #2
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Me too, I need negative.
nick1983 is offline   Reply With Quote
Old 06-14-2007, 04:34 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
You guys check with Invision, Wesellcarparts and Dezod? I think heylookatjames had camber bolts but not sure where from. Doesn't one of the thai guys have camber bolts?
SPONSORED BY
Old 06-14-2007, 07:03 PM   #4
largeorangefont
Break'em off some.
I bought some on Ebay for a Scion XB for $15 shipped. We will see if they fit :)
Old 06-14-2007, 07:30 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
I am pretty sure these are just a smaller diameter grade 8 bolt
Old 06-14-2007, 07:54 PM   #6
brickhardmeat
Lonesome Cowboy
there is a guy here with these
Toyota OEM 12.4mm Front camber bolts (-2 deg camber)
http://www.yarisworld.com/forums/sho...t=camber+bolts
SPONSORED BY
Old 06-14-2007, 11:11 PM   #7
largeorangefont
Break'em off some.
No it is an eccentric bolt, just like the one above.
Old 06-14-2007, 11:14 PM   #8
largeorangefont
Break'em off some.
Old 06-14-2007, 08:47 PM   #9
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
My local alignment shop came up with these no-name bolts that gave my car the camber I wanted. Its adjustable from 0-2 degrees negative I believe.
Old 06-14-2007, 11:59 PM   #10
Black Yaris
der Zeck
then you can get them at Napa
Old 06-26-2007, 09:07 PM   #11
brickhardmeat
Lonesome Cowboy
you ever get the camber bolts installed?
SPONSORED BY
Old 06-26-2007, 10:38 PM   #12
largeorangefont
Break'em off some.
I'm installing them this weekend. I have a camber guage I will use to dial in the camber.
Old 06-27-2007, 07:49 AM   #13
YamilR
YamilR's Avatar
http://www.ptuning.com/html/search-r...c&cmbYear=2007
Old 06-27-2007, 09:49 AM   #14
brickhardmeat
Lonesome Cowboy
cool
SPONSORED BY
Old 06-27-2007, 10:13 AM   #15
largeorangefont
Break'em off some.
Save $10 and get them on Ebay. Mine were $15 shipped, they are the same ones.
Old 06-27-2007, 10:32 AM   #16
brickhardmeat
Lonesome Cowboy
maybe kinda dumb question. Can you still use tuner nuts on these?
SPONSORED BY
Old 06-27-2007, 05:09 PM   #17
largeorangefont
Break'em off some.
Yea. These are the bolts that attach the bottom of the strut to the spindle. There are 2 per side. You replace the upper bolt on each side with the camber bolt and leave the stock bolt on the bottom.
Old 07-07-2007, 02:14 AM   #18
brickhardmeat
Lonesome Cowboy
Originally Posted by largeorangefont View Post
I need some.
so what happened, I've been looking forward to an upadte, got 'em installed?
SPONSORED BY
Camber kit FunkyCole Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-05-2009 04:28 PM
Camber kit FunkyCole Performance Modifications 0 06-12-2007 07:26 PM
The ultimate question... WHY? Beware, nothing in this post makes sense. spkrman Off-topic / Other Cars / Everything else Discussions 26 05-30-2007 01:01 AM
Dont forget the camber bolt. nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-23-2007 04:39 AM
Camber Kit? LoudYar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-12-2007 09:58 AM
