Drives: yaris Join Date: Mar 2023
Wiring Diagramfor 2018 yaris
Hi! I´m from Argentina. I have a 2018 Yaris manual transmision. If someone have the Cruise Control wire diagram, Because I made the connection for the cruise control, it turns on but does not "SET". And I don't know if I'm missing some cable in the ECU for the clutch or what. Thank you
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Search the site for "cruise control". There is a switch required for manual transmissions.
The switch mounts on the clutch pedal bracket. Its purpose is to cancel the cruise control when you push the clutch pedal. The connecting wires should already be in the wiring harness, but are most likely taped up inside it.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Tags |
| cruise control |
| Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
| 2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 11:56 AM |
| Need Toyota Yaris 2003 tail or backlight wiring schematic | Martintim | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 08-22-2016 10:35 AM |
| 99 Yaris alarm wiring | Povo | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 08-03-2012 04:47 AM |
