Old 08-14-2007, 08:41 PM   #1
Kaeon
Drives: 2007 Yaris Hatch
Lowest Drop On Springs?
I was looking at the Yaris with the TANABE DF210's and I love the stance. Is there any springs out there that will drop the car a little bit more? Or is the TANABE about the lowest you can go?
Kaeon is offline   Reply With Quote
Old 08-14-2007, 09:20 PM   #2
YamilR
YamilR's Avatar
As far as I know If you don't want to invest in coils , DF should be the lowest drop
Old 08-14-2007, 09:46 PM   #3
Thotprawsis
Drives: '07 Blazin' Blue LB
DF210's are the lowest drop on springs that I know of.How you are going to drive it? Check out several posts on the different combinations other users have tried and how they are using their cars. Some swear by the coil overs...generally the ones that like to push their cars to the limit. Do a search on Tein basics. I personally have the DF,s and I love them.
Thotprawsis is offline   Reply With Quote
Old 08-14-2007, 10:16 PM   #4
i believe that the Tein S.Tech's have the greater drop.
Tanabe's specs
http://www.tanabe-usa.com/springs/sp...tions.asp?id=1
Tein's specs
http://www.tein.com/stech.html
Old 08-14-2007, 10:26 PM   #5
Kaeon
The car is just a DD that I use for highway by no means is this car a race car lol! I just want a low stance on springs thats not to harsh of a ride.
Kaeon -
2007 Toyota Yaris Hatch
Old 08-15-2007, 01:14 AM   #6
hmmmm, i think i would go with the Tanabe's since my friends and family say my Tein and TRD set up is a little too stiff/firm/"bouncy" (in their words). but for me, i actually want it a little stiffer.
Old 08-15-2007, 03:46 AM   #7
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
can somebody confirm this?? i already send back my Tanabe DFs..
only because people here said Tein is way better,in comfort..less bouncy and better handling than the Tanabe.
last Friday night at the meeting,
i test drive a Yaris with that DFs..and it felt okay actually.
and i was surprise when the owner suggested to get the Tein instead.
Most people i asked in here said Tein,
Autobacs said Tanabe,
my buddies at VW Vortex said Eibach or H&R,
i pick Tein..!!
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-17-2007, 02:01 AM   #8
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
i pick Tein..!!
Tein is the way to go for sure. Eibach and H&R will always be what a VW owner tells you to get.. but they are far from the best. (not bad mind you) Tanabe are good but Tein sustains the normal ride of the car best.
Old 08-19-2007, 04:50 AM   #9
seanele
seanele's Avatar
dude..thanks for this..
i got the Tein spring(finally..!!), and this time i want to keep it.
the Tanabe DF i bought the other day from friend in Jersey, i sent it back..
Old 08-19-2007, 11:13 AM   #10
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
once settled, my DF's dropped a hair over 2" all around.
some people like myself actually measure these things before and after...
Old 08-15-2007, 01:19 AM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
lowest drop you can rurrently get by replacing the coils only is with the Tein s-techs..... 1.9 F&R
Old 08-15-2007, 02:07 AM   #12
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
yup teins for sure has the lowest drop followed by df's
Old 08-15-2007, 03:39 AM   #13
seanele
seanele's Avatar
Tein is 1.9 drop,
if you find any other spring lower than that, then i'm too slow in searching..
Old 08-15-2007, 04:21 AM   #14
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you want it low, just cut a coil or two off the df's or teins or whatever. the ride will be bouncy and your shocks will die really quickly but you can put your car on the ground if that's what you're after.
reznunt is offline   Reply With Quote
Old 08-15-2007, 09:32 AM   #15
Black Yaris
der Zeck
cut coils do not make you car bouncy, and they do not kill your struts any faster... that is just being dumb.... that is like saying lowering your car is going to kill your struts and make your car bouncy....
Old 08-15-2007, 12:12 PM   #16
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
lowering your call WILL kill your struts faster than if you didnt lower them.
AlphaFox is offline   Reply With Quote
Old 08-15-2007, 05:23 PM   #17
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
obviously you haven't done this before. or maybe you are talking about aftermarket shocks. with oem shocks, first your seals die and leak oil and then you bounce around town. or, if you cut enough coils off and end up sitting on your bumpstops, then when you hit a bump at speed you have no down travel on the shocks which will also make the ride feel "bouncy". he'd be safe with cutting a coil or two, but if he starts bottoming out then the shocks will go soon after. the end.
Old 08-15-2007, 03:16 PM   #18
i thought cutting a coil or two will make your car more bouncy.
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Minimal Drop From Springs blacksan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-15-2007 05:46 AM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 08:29 PM
