Old 06-20-2007, 06:51 AM   #19
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Hey guys and galls.. Something has come up and I won't be able to install the LED mirrors for the next week.
Hopefully we have someone else step in to complete the DIY.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 06-20-2007, 11:11 PM   #20
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
You suck.
Old 06-22-2007, 03:25 AM   #21
ed_pantera
Drives: White yaris
cool !
ed_pantera is offline   Reply With Quote
Old 06-30-2007, 03:40 PM   #22
Violin
Violin's Avatar
OK - The fact that not one of the tabs matches is not an unmitigated disaster. Just cut 'em off.
Remove the inner door panel and take the mirrors off the doors by removing the three 10mm nuts holding them on.
If you have power mirrors, use the existing wire to help you fish the new wires through. Pull the wire back toward the mirror all the way so the power mirror connector bumps tight:
Tape your LED wires to this wire:
Pull everything through:
Unwrap the tape and you're in business:
Cut the tabs off the inside of the Sakura mirror cover - they are just in the way.
Get yourself some clear silicone window/door caulk:
Carefully run a clear bead inside the mirror:
Put the LED mirror cover in place:
Wipe off any excess sealant and wrap with blue painter's tape until dry:
Old 06-30-2007, 03:45 PM   #23
Violin
Violin's Avatar
I'll probably let this cure overnight and wire them up tomorrow. Black is ground, gray is the white running light and red is the amber blinker light.
Old 06-30-2007, 07:04 PM   #24
bigsky2
Cousin Vitz
bigsky2's Avatar
You rock.
Old 06-30-2007, 07:13 PM   #25
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well done, Violin! Great attention to detail!
Old 07-01-2007, 04:35 AM   #26
woah thanks a lot, Violin, this is a very good solution!!!
Old 07-01-2007, 05:25 PM   #27
Violin
Violin's Avatar
Old 07-01-2007, 06:06 PM   #28
Violin
Violin's Avatar
Here we go:
I took my speakers out and ran the wires down through the door
and fed it through the boot into the cabin
On the passengers side I ran the wire through the firewall using the grommet for the rear window washer hose
On the drivers side, I jacked up the car to get access to where the hood latch runs through
In ran just the power wire for the blinker through (red) into the engine compartment.. The ground (black) was grounded inside the cabin. I crimped a ring terminal on the ground wires
To access the blinker circuits, I popped the top of the bumper off and removed both headlights. There is a bundle of wires running under each from inside the fender. The driver's side power wire was hooked to the smaller green striped wire here
Using quick splice connectors, like so
and the passenger's side goes to the green wire here
Like so
I decided not to use the white LEDs (gray wire) as I don't know if its legal to have white running lights on your mirrors here. I may hook them up so I can switch them on/off at will.
Here's a video clip of the blinker in operation:
click to watch
Movie clip - click to watch
Old 07-02-2007, 12:33 AM   #29
Edd
Drives: None
Looks great, I thought it was a bit dim, but it looks normal in the nighttime video.
Edd is offline   Reply With Quote
Old 07-02-2007, 07:13 AM   #30
Violin
Violin's Avatar
Yeah - where you only see the LEDs during the day, the whole reflector area lights up at night.
Old 07-03-2007, 03:22 PM   #31
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
can you see the blinker light from behind?
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 07-03-2007, 04:56 PM   #32
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
look really nice.. if only it was really fitting lol
OxyG3nE is offline   Reply With Quote
Old 07-03-2007, 09:30 PM   #33
Violin
Violin's Avatar
No. I'd think that would be pretty distracting to the Yaris driver. It is visible from the side - better than 90 degrees out.
Old 07-03-2007, 10:22 PM   #34
uncleyaris
one fantastic job!! They look great. I wish I could get them in my colour. congrats.
Old 07-04-2007, 11:09 AM   #35
vodkalush
I drive a yarrrris
vodkalush's Avatar
Since you can't see it from the side, I think I'm gonna switch the two, so the turn signal is in white...
will work for parts
Old 07-05-2007, 08:10 AM   #36
Violin
Violin's Avatar
Meaning to the side and a little bit back.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 07:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 07:23 AM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 11:58 PM
