Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
DIY: Replacing Stock Mirrors
This DIY is another easy one (my specialty)...should take no more than one hour tops!
This DIY is for replacing your Yaris liftback stock mirrors. This is a great alternative if you have considered installing power mirrors or mirrors with LED turn signal indicators/parking lamps onboard. This is also an alternative to stick-on and replacement mirror covers. 1. Remove your door panel. Refer to the following DIY for instructions on this step: http://www.yarisworld.com/forums/sho...+panel+removal 2. The mirror is attached via 3 screws with nuts hidden behind three access holes. 3. Using a wrench with extension remove the 3 nuts from the mirror screws. Observe the base plate that holds the mirror on the car and placement of the 3 screws. Also note from the outside of the car the 3 holes the mirror uses for the screws. ***NOTE: Unless you have tiny fingers or are ultra careful you are guaranteed to lose at least a couple of these nuts in the door (Good news is if you do lose them they are easy to retrieve with a magnetic screwdriver and small needle nose pliers). 4. Remove the factory mirror. Sell on Ebay. 5. Install new mirror. I chose a chrome manual K6 style mirror with LED insert that illuminates in sync with the turn signals and parking lights. I t came with 3 wires (black = ground/white = signal light/blue = parking light) The supplier had one available with a 3 hole base plate that fit the Yaris liftback perfectly. I threw away the 3 screws supplied and chose bolts instead with washers for a more secure install. 6. Reinstall the door panel wrapping the 3 LED wires under the rubber weather seal on the door to hold in place. 7. Run the 3 wires to appropriate locations (NOTE: you may need additional wire to complete this part). To access side marker turn signal light go thru the black trim piece in front of the mirror base). 7. Enjoy your new Yaris look with the new mirrors!!!!!!!
Bringin the Bling to Yarisworld Last edited by redyaris; 06-21-2007 at 09:59 PM. |
Part 2 pics
Bringin the Bling to Yarisworld |
Wow... pretty kewl replacements...
![]() Where did you get 'em? Nice DIY BTW... Thanks!
Thanks tk! I got em on ebay of course from a reputable seller I highly recommend (the same one I got my chrome door handles from). Shipping was ultra fast (less than one week!!!)
'best in parts' is the sellers ID. Do a search for them.
Very nice write up and nice pictures to go with it.
der Zeck
nice write up, not fond of the product, but nice DYI on the process
you are getting a lil Ricey there RedYaris
#7 | |
Heart Up! Vitz
Now does this apply to Yaris owners w/o power operated side mirrors? Because I have power operated side mirrors so......I want to be careful w/ that part of the wiring. I like my power adjusted side mirrors~
Because the last thing I'd want would be having something fashionable but not functional.... |
#9 | |
My search for "Yaris power mirrors" yielded no results. Are your side mirrors designed for a different car model?
woah... quick! to the bling-mobile
![]() Nice to see some more options for mirrors, anyway
Here's a link to the sellers store:
http://stores.ebay.com/Best-in-Parts and here's a link to the exact mirror i bought: $99 power, $69 manual (+ shipping). You can order the power one online but for the manual one you have to email the seller direct. For those seeking less bling, it is available in black too. http://cgi.ebay.com/ebaymotors/K6-Ch...3962QQtcZphoto bestinparts is the seller. Highly reliable and good product. Tell em redyaris sent you!
Bringin the Bling to Yarisworld Last edited by redyaris; 06-22-2007 at 05:29 PM. |
Part 3 pics: wiring
The mirrors I purchased came with three wires from the LED insert Blue: routed to parking light White: routed to turn signal sidemarker Black: routed to ground Supplies: I purchased a roll of 18 gauge wire from AutoZone ($5) along with a package of quick splice connectors ($3). To wire the mirror LEDs you will need to remove the front bumper cover. This is easy! (My thanks to Tiksman for showing me this from the get go with this car!)....There are 6 little black plastic connectors that hold the bumper cover in place (4 under the hood and 1 in each front wheel well). To remove these connectors poke something into the connector center and then pull the connector out. Then pull the bumper from onboard connector panels at each front quarter panel. It will separate without having to remove any screws....When you do this, the bumper cover will drop down giving you access to the headlights. You will next need to remove both headlamp housings. To do this remove 3 screw bolts from each housing (2 of the screw bolts are visible from the top of the headlights and 1 is located on the fender side of the headlight). Move the headlamp housings out of the way. Now you can easily reach inside the front fender and remove the side marker lamp housings by squeezing each side and twisting it out of the fender. Next run your extra wire from the mirror wires into the front fenders via the black plastic trim piece immediately in front of the mirror mount. No need to remove the trim piece just insert the wire below it. Go around to the headlight area and fish the wires into the engine compartment. Find any suitable chassis bolt to run the black ground wire to on both sides of the car. Using a quick splice connector, run the extra wire from the blue wire to the parking light on the back of the headlamp housing. There is a green wire and a white wire. Quick splice into the green wire and your extra wire (blue wire source). Using another quick splice connector, run the extra wire from the white wire to the side marker turn lamp. Here also you will find a green and a white wire. Quick splice into the green wire and your extra wire (white wire source). Make sure you wrap all exposed wires and quick splice connects with electrical tape to prevent exposure to moisture and to prevent shorts. Test your LED mirrors at this point before you remount everything. The LED mirrors should illuminate steady with the parking lamps and also flash in sync with your side marker turn lamps. If your LED mirrors fail to illuminate check all wires for connections, check your ground wires (I know because my right mirror did not come on, I had a loose ground wire)... Thats it. Remount your side marker lamps, headlamp housings and mount the front bumper cover. Enjoy the LED mirrors!
heh I think you've saved me a lot of time in writing up my last part of the DIY
#15 | |
Heart Up! Vitz
Thanks a lot redyaris, appreciate it! |
#16 | |
Nice that I do your work for you Teacher!!! Give me some props people!!!
Consider it homework.. though you're not even in my class???
![]() A question, though, instead of wiring all the way to the front headlight for the parking light signal, could you not connect them to illumination wires in the cabin somewhere? For example, I have power windows, and on the driver's side, the AUTO text on the switch is illuminated whenever the headlights are on, and I was thinking to tap into that wire, and find a similar one on the passenger side. Whaddaya think?
Thanks for the write up. It will make it a little easier for us that got our mirror covers through the recent Thai group buy.
I can't really picture how you routed the wires though. Did you fish them through the boot with the rest of the wires from the door and then out through the firewall or what? |
| Yarisworld.com DIY Manual v3 | vodkalush | DIY / Maintenance / Service | 101 | 06-25-2024 12:10 AM |
| "Official" Yarisworld.com DIY Manual | vodkalush | DIY / Maintenance / Service | 41 | 11-02-2023 11:47 PM |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Replacing stock deck - photo tutorial | gravylegs | In Car Entertainment + Electronics (audio / video / alarm) | 39 | 02-06-2012 01:04 PM |
| replacing stock rims after the winter | mikeukrainetz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-24-2007 09:36 AM |
