#19 |
![]() ![]() Drives: 07 HB Join Date: Apr 2007
For someone like me who knows nothing about sway bars, or how they affect understeer ect.. it is nice to have real answers.
#20 | |
Modded Moderator
![]() Etimago, could we please take care of these smart asses? A lot of people here are getting tired of this. This should not be part of these kinds of threads. It isn't helping anyone. |
#21 | |
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
Sway bars are basically springs. Funny shaped springs, but springs all the same. By replacing your stock sway bars with thicker ones you increase the spring rate. This is good for reducing body roll, when you're turning at speed and the weight in the car shifts to one side. The thicker sway bar resists weight transfer, stays flatter, and you stay in the center of your seat. There are downsides to really thick sway bars, though. The Yaris is a FWD car, and to make a long story short putting a really big bar in the back without balancing it out with a bigger bar in the front can induce oversteer. You try to take a corner and the rear end whips around. Put a big bar on the front without a balanced bar on the back, you induce understeer. You try to turn and the car keeps going straight. I don't know anything about aftermarket suspension parts available for the Yaris. Generally you don't want to put a thick front sway bar on your car unless your having problems with oversteer. Most of the time that happens because you've put on a rear bar that's too large. As a result, most of the time front and rear bars come as a set. The same isn't necessarily true of rear bars. For other FWD cars (I have no idea what the Yaris aftermarket is like) you'll see a lot of rear sway bars sold alone that are slightly thicker than stock. You can generally get away with stiffening up the rear sway a bit without inducing so much oversteer you need a front sway. So, the front sway doesn't tend to be useful without a thick rear sway to go with it. If there isn't a really thick rear sway on the market yet all it'll do is induce a bunch of understeer and plant you firmly into the barrier when you take an offramp. That help at all? |
#22 |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I think we could do without personal attacks with the exception of a little teasing and leg pulling but there is going to be indifference here. I don't think anyone has said anything that merits anything more than the line I'm dropping right now. This thread will probably be locked but everyones' opinion on the stuff remains.
Aren't we MEN here? I mean, shit. Forget about it.
SPONSORED BY
#23 |
One of my favorite, definite pages on understeer/oversteer. I take a copy of this to the track with me:
http://www.rogerkrausracing.com/Tech...verunder.shtml [ compliments of Roger Kraus Racing ] and here is Ingalls primer on Tuned Suspensions, which I found very useful with my car: http://www.ingallseng.com/performance/primer.html
#24 |
Go on Wikipedia and look up the following terms for a crash course in Yaris suspension...
Oversteer Understeer Torsion beam suspension Sway bar Strut bar Past that, I could recommend a book or two, but for most the above reads will be more than sufficient. Just try and bear with the terminology. Once you read those and go drive your car hard again you'll understand why this part is meaningless for most of us. |
| Strut Bar or Sway Bar | blacksan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 04-30-2007 09:31 PM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 02-22-2007 11:08 AM |
| Sway Bar! | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 55 | 01-12-2007 03:31 AM |
| Sway bar | chrisada_to2a | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 09-05-2006 07:34 PM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | General Yaris / Vitz Discussion | 3 | 08-30-2006 09:43 PM |
