Old 04-30-2007, 04:35 PM   #1
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Strut Bar or Sway Bar
So, what gives the most benefit with otherwise stock setup?
blacksan is offline   Reply With Quote
Old 04-30-2007, 05:28 PM   #2
blacksan
blacksan's Avatar
Ok, no reply which leaves me in the position to place foot-n-mouth. I would assume that with FWD the strut bar gives more seat of the pants input with stock setup.
Old 04-30-2007, 05:31 PM   #3
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
I got both the front strut tower bar and the rear anti-sway bar. Body roll is virtually gone. I couldn't tell you which helped more, but I would assume the anti-roll bar.
Ran Kizama is offline   Reply With Quote
Old 04-30-2007, 05:34 PM   #4
blacksan
blacksan's Avatar
With the front struts so close to the firewall you are most likely correct. is your sway bar TRD?
Old 04-30-2007, 05:38 PM   #5
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I'm going for everything all together but just lowering the car and getting wider tires on seems to make a huge difference.
SPONSORED BY
Old 04-30-2007, 05:39 PM   #6
blacksan
blacksan's Avatar
I want to get a few miles on her before the radical suspension upgrades.
BTW, the more I drive this dam thing the more I like it!!!
Old 04-30-2007, 05:41 PM   #7
brickhardmeat
Lonesome Cowboy
nothing radical, you'll like the driving a ton more, I could hardly get the thing home stock, it felt like such crap
SPONSORED BY
Old 04-30-2007, 05:53 PM   #8
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Yup. Fairly cheap and takes about 10mins to install. Kind of hard to go wrong. I recommend checking out trdsparks.com for the best price.
Old 04-30-2007, 09:31 PM   #9
blacksan
blacksan's Avatar
Originally Posted by echo_hrs View Post
At the risk of starting one of those suspension setup knowledge pissing contests, I've found that the rear TRD sway reduces the understeer and front wheelspin in corners, and also helps rotate the rear of the car around the corners immensely...
I would venture to say it does much more than a strut bar so close to the firewall...
Cheers
ya but, I want to start a pissing contest among web super hero's!
I think you are most likely correct in your assumption.
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 03:31 AM
