![]() ![]() Drives: Yaris Join Date: Oct 2006
engine knocking when accelerating
These days I notice my Yaris Sedan gets engine knocking when the car is accelerating.
My car gets 10,000 miles already and I am using Sam's Club 85 gas. In Utah's Sam's Club, we only have 85 and 91 as options. I have been using Sam's fuel for two month and just notice this problem these days... Is there any problem with using 85 fuel in Sam's? Do I need to switch to 91 in Sam's or another gas station? Thanks a lot!! |
Tired of the Stars!
Minimum rating is 87... hence the knock. Try a higher octane.
It is really harmful if I kept using 85 for over 7 months? In Utah, most stations have 85 as the lowest option which is called unleaded gas...
![]() ![]() ![]() Drives: 07 yaris s sedan Join Date: May 2006
it's only harmful if it's actually knocking that whole time, but you really should run 87 in it.
do not let it continue to knock unless you want to replace the engine soon.
2007 S Sedan, NF210's, 5% rear windows, 35% front two, Sirius S50, 15" black konig heliums
Oh MY GOD!! I DON"T EVEN KNOW THAT I SHOULD USE 87fuel....
WILL CAR BE REALLY DAMAGED BECAUSE I KEPT USING 85 BEFORE??? I WILL SWITCH TO 91 IMMEDIATELY!!! WE ONLY HAVE 85 and 91. HOWEVER, WHEN I GET THE CAR FROM THE DEALERSHIP OCTOBER, THE SALESPERSON TOLD ME JUST USE THE CHEAPEST FUEL. OH MINE!!!! CAN ANYBODY KILL ME? I AM SO SAD...... WILL THE SITUATION GETS BETTER WHEN I SWITCH TO 91 TOMORROW???? UPDATE: I JUST CALLED THE SALESPERSON TONIGHT, HE TOLD ME UTAH IS ON HIGHER SEA LEVEL SO THAT 85 IS FINE FOR MOST OF CARS. HE IS BS!!! ANYWAY I WILL SWITCH TO 91 AT CHEVRON TOMORROW. |
I have never heard of anything under 87 octane, and does anyone know of a car that runs that at minumum other then a Chevy Colt or a Ford Fiesta.
Chode
Drives: Silver 5 Door YRX 1.5L I4 Join Date: Feb 2007
in australia, we get 91, 95 and 98. didnt think that it went that low these days...
only use the lower octane for older cars with the smaller compression ratio. the standard it about 9.5-11:1, depending on what car it is (economy-sports respectively) |
#8 | |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
Capagotks, in Australia we use a RON number. Americans, who love to be different, use (RON+MON)÷2.
So basically our fuels are the same as the ones in the US. Europe have better fuels than both of us. |
#9 | |
Chode
#10 | |
![]() ![]() Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
You're probally getting knock because of the summer heat. Hot air explodes easier than cooler air. Thats why You run richer in the winter and leaner in the summer - but the computer corrects for it. Also thats why carbs need to be retuned every season to run the best. |
Yeah, proly use better gas from now on. Take it to dealer if you hear that noise again. Good luck!
The car has a knock sensor so your car should be fine. even 87 is questionable with 10.5:1 comp,you will be losing power also from the ecu pulling timing. I've been running 91 and it does feel more powerfull in the midrange.
#13 | |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
I haven't notice any real advantages with performance (premium vs regular), however on occasion, the engine will feel a little more sluggish then usual, but those isolate occurrence only happen when I'm running on regular gas (probably caused by a bad batch gas, with octane level lower then the required 87). |
#14 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Haven't heard that one before????? Who told you that?????
____________ Old School Cobble Jockey
#15 |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
This is just for information and reference (please refer to Post #3849 thereof)
:http://townhall-talk.edmunds.com/Web...her%20altitude I can't judge the validity of all the comments. Edit: Here is another link: http://www.bp.com/liveassets/bp_inte..._car_knock.pdf Middle of Page 2 thereof is relevant. Last edited by swng; 07-04-2007 at 01:30 AM. |
#16 | |
| engine question... (2ZR-FE and 2ZZ-GE) | Avia | General Yaris / Vitz Discussion | 5 | 12-24-2010 08:16 AM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
| Engine bay prettification project | eTiMaGo | Cosmetic Modifications (Exterior/Interior) | 14 | 04-23-2007 04:22 PM |
| wtb 1nzfe engine blown or working | turboyaris | Items for Sale by private party | 5 | 04-08-2007 02:03 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
