Old 07-07-2007, 12:36 AM   #37
toyota-belta
Drives: toyota belta s importer
Originally Posted by Violin View Post
Here we go:
I took my speakers out and ran the wires down through the door
and fed it through the boot into the cabin
On the passengers side I ran the wire through the firewall using the grommet for the rear window washer hose
On the drivers side, I jacked up the car to get access to where the hood latch runs through
In ran just the power wire for the blinker through (red) into the engine compartment.. The ground (black) was grounded inside the cabin. I crimped a ring terminal on the ground wires
To access the blinker circuits, I popped the top of the bumper off and removed both headlights. There is a bundle of wires running under each from inside the fender. The driver's side power wire was hooked to the smaller green striped wire here
Like so
and the passenger's side goes to the green wire here
Like so
I decided not to use the white LEDs (gray wire) as I don't know if its legal to have white running lights on your mirrors here. I may hook them up so I can switch them on/off at will.
Here's a video clip of the blinker in operation:
click to watch
Movie clip - click to watch
my file is to pass everywhere ok I would like to know or that I connect the wire
toyota-belta is offline   Reply With Quote
Old 07-07-2007, 08:06 AM   #38
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
ummm.... what?
Old 07-07-2007, 08:51 AM   #39
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
dit moi ses quoi tu veut luis demander et je vais luis traduire!
(tell me what you want to say and Ill translate it!)
the_boss is offline   Reply With Quote
Old 07-07-2007, 08:52 AM   #40
the_boss
the_boss's Avatar
freaking nice DIY by the way
it's legal in canada to have white running light on mirror some FJ cruser have some little round white light on the mirror!
Old 07-07-2007, 12:19 PM   #41
toyota-belta
bonjour je voudrais savoir ou me brancher pour que mes cover marche avec mes flocher merci
toute mes file sont passer de la porte il me reste a me connecter
merci beaucoup
Old 07-07-2007, 12:53 PM   #42
the_boss
the_boss's Avatar
merci beaucoup
Hey Violin, this guy would like to know where to take the power to have his signal light flashing with his reg, flasher. Everything is ready but he need to know where to tap to get the juice!
Hope you understand what I mean !!
thanks
Old 07-07-2007, 03:47 PM   #43
Violin
Violin's Avatar
There is a bundle of 4 wires running up from inside the fender to up under each headlight. Those are the ones I have pictured. You have to remove the headlights to get at them. Tap the wires I showed for power - the red wire from the mirror is the power wire for the amber LED and the black is the ground. The ground can go to just about any bolt inside the cabin.
Thanks for translating.
Old 07-07-2007, 07:15 PM   #44
the_boss
the_boss's Avatar
Ok here we go!
Ya une couette de 4 fils qui passe dans chaque coter de fender (aile) jusqua la lumiere avant. ses ceux qu'il a photographier. Faut enlever l'assemblage de la lumiere pour y acceder. tap le fil qui apporte le courant au blinker avec le fil rouge du miroire (courant pour les led jaune) et le noir ses le ground ou mise a la terre, tu peut grounder sur n'importe quel boulons pis sa va faire!
NOTE DE MOI MEME: prend le fil conducteur des blinker avant pis plug les avec le rouges des led jaune du mirroires. dans sa photo y montre quel fil tu doit connecter!. Jespere que sa va aider!
Old 07-07-2007, 08:17 PM   #45
love the global community around here!!!
I am definitely doing this mod. Anyone know where I can get CF LED mirrors?
Old 07-07-2007, 08:28 PM   #46
one more thing. If you don't mind my asking, why not just wire to the side marker, which is only about a foot away from the mirror?
Old 07-08-2007, 08:08 AM   #47
Violin
Violin's Avatar
You could do that, I even had mine popped out for that purpose but decided it was neater where I tapped it.
Old 07-20-2007, 08:36 PM   #48
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
im gonna get rid of my side markers with this mod, lol, is way better
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 07-20-2007, 09:30 PM   #49
Violin
Violin's Avatar
You'll patch and paint the holes in the fender?
Old 07-21-2007, 08:47 AM   #50
bigsky2
Cousin Vitz
bigsky2's Avatar
Wish me luck guys, I'm going to attempt the install today.
Violin - Did you remove all the clips from the Sakura mirror cover? I'm wondering if it's sufficient to just hack off the one that does not match and fit the mirror cover on as is. Is the caulk necessary?
Old 07-21-2007, 10:46 AM   #51
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Because he's anal.
Old 07-30-2007, 05:45 AM   #52
bigsky2
Cousin Vitz
bigsky2's Avatar
Finally got my mirror covers wired up and installed.
I'll take some pics tomorrow evening and post them up.
Thanks to Violin for the excellent DIY.
Old 07-31-2007, 05:14 AM   #53
bigsky2
Cousin Vitz
bigsky2's Avatar
Here we go.
Old 07-31-2007, 05:19 AM   #54
looks good man, is the "white" light really that blue in person or is your camera playing tricks?
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 10:58 PM
