#37 |
![]() Drives: toyota belta s importer Join Date: Sep 2006
my file is to pass everywhere ok I would like to know or that I connect the wire |
#38 |
ummm.... what?
#39 |
![]() ![]() ![]() Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
#40 |
![]() it's legal in canada to have white running light on mirror some FJ cruser have some little round white light on the mirror! |
#41 | |
bonjour je voudrais savoir ou me brancher pour que mes cover marche avec mes flocher merci toute mes file sont passer de la porte il me reste a me connecter merci beaucoup |
#42 | |
Hope you understand what I mean !!thanks |
#43 |
There is a bundle of 4 wires running up from inside the fender to up under each headlight. Those are the ones I have pictured. You have to remove the headlights to get at them. Tap the wires I showed for power - the red wire from the mirror is the power wire for the amber LED and the black is the ground. The ground can go to just about any bolt inside the cabin.
Thanks for translating. |
#44 |
Ok here we go!
Ya une couette de 4 fils qui passe dans chaque coter de fender (aile) jusqua la lumiere avant. ses ceux qu'il a photographier. Faut enlever l'assemblage de la lumiere pour y acceder. tap le fil qui apporte le courant au blinker avec le fil rouge du miroire (courant pour les led jaune) et le noir ses le ground ou mise a la terre, tu peut grounder sur n'importe quel boulons pis sa va faire! NOTE DE MOI MEME: prend le fil conducteur des blinker avant pis plug les avec le rouges des led jaune du mirroires. dans sa photo y montre quel fil tu doit connecter!. Jespere que sa va aider! |
#45 |
love the global community around here!!!
I am definitely doing this mod. Anyone know where I can get CF LED mirrors?
#46 |
one more thing. If you don't mind my asking, why not just wire to the side marker, which is only about a foot away from the mirror?
#47 |
You could do that, I even had mine popped out for that purpose but decided it was neater where I tapped it.
#48 |
El Yoe
im gonna get rid of my side markers with this mod, lol, is way better
Cuban to the bone, sitting in a Yaris, ahi si hay!!... |
#49 |
You'll patch and paint the holes in the fender?
#50 |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Wish me luck guys, I'm going to attempt the install today.
Violin - Did you remove all the clips from the Sakura mirror cover? I'm wondering if it's sufficient to just hack off the one that does not match and fit the mirror cover on as is. Is the caulk necessary?
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
#51 |
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Because he's anal.
Bringin the Bling to Yarisworld |
#52 |
Cousin Vitz
Finally got my mirror covers wired up and installed.
I'll take some pics tomorrow evening and post them up. Thanks to Violin for the excellent DIY.
#53 |
Cousin Vitz
Here we go.
#54 |
looks good man, is the "white" light really that blue in person or is your camera playing tricks?
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY for Low Cost Dim Light in the light LED | tang | DIY / Maintenance / Service | 0 | 03-08-2009 10:58 PM |
