Old 07-31-2007, 05:37 AM   #55
bigsky2
Cousin Vitz
bigsky2's Avatar
It's got a tint of blue in it, as with any white LED if you look at it long enough.
But yes, the camera makes it look bluer than it would to the naked eye.
Old 07-31-2007, 05:49 AM   #56
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great install! Looks awesome bigsky2!
Did you add a switch in order to change between LEDs easily? If so, could you please let me know which model you used? Thanks!
Old 07-31-2007, 05:56 AM   #57
bigsky2
Cousin Vitz
bigsky2's Avatar
tk-421:
Edit:
I completely ignored your question.. Sorry.
I did not use a switch, but instead I ran the power wire for the white LEDs to the engine area and tapped into the parking light power wires. The rules/laws regarding automotive lighting is not strictly enforced here, so I decided to wire it that way for convenience. I drove by a few police cars over the last couple of nights and they didn't give me any problems.
In addition to Violin's suggested wiring, I also tapped into the parking light power wire in the engine area. I removed the headlights, opened up the bundle of wires inside each fender, and performed a "tug test" to determine which green wire belonged to the parking light on each side. I pulled each green wire until my girlfriend felt that the green power wire from the parking light began to pull/wiggle.
I then ran the grey power wire from the mirror cover to the engine area and used a quick splice (t-tap) connector to tap into the parking light power wire. The white LEDs on the mirror cover will only turn on if I turn on the headlights to the first position (Parking lights only) or to the second position (Parking Lights + Low Beam lights).
I chose to do it that way as I didn't want the white LEDs to be on as soon as the e-brake goes down and the DRLs turn on.
Old 07-31-2007, 06:09 AM   #58
bigsky2
Cousin Vitz
bigsky2's Avatar
Attention non-Thailand owners who wish to install this mirror cover, or for anyone who has to cut the clips and apply this by sealing.
Do NOT use acrylic polymer to seal the mirror covers to the mirror assembly. I thought I was all smart and cool when I decided to use some left over sealant I had at home to affix the mirror covers..
Big mistake.. LOL.
I let them cure for a day and a half, with tape on the mirror to hold the covers in place.
When I removed the tape, the sealant was still wet and all it took was a simple tap and the mirror cover came off.
After I cleaned everything off, I went to the store and purchased a silicone based sealant that had better adhesion to plastic. Coincidentally I ended up choosing the same sealant that Violin used: Silcone II window/door sealant by GE.
It has superior adhesion to plastic and created an excellent seal for the covers. Just make sure you cut a small piece off the tip so that the bead size is thin, allowing you more precision as you run along the mirror assembly.
Old 07-31-2007, 06:12 AM   #59
bigsky2
Cousin Vitz
bigsky2's Avatar
looks good man, is the "white" light really that blue in person or is your camera playing tricks?
BTW - thanks to you too for the excellent DIY (part one)
I thought I broke my mirror clips when I took them off for the first time...
Old 07-31-2007, 06:13 AM   #60
hahah yeah, now if only I could actually finish wiring them up myself someday
Old 07-31-2007, 06:14 AM   #61
bigsky2
Cousin Vitz
bigsky2's Avatar
It'll be hella fun Thomas...
If you are anal like Violin and myself, you'll enjoy getting those wires through the boot!
Old 07-31-2007, 06:18 AM   #62
oh I am the anti-anal (oral?), I'm Mr. Ghetto wiring... I don't even think I can find vampire tap thingies here, gonna trust my good old swiss army knife to cut insulation, and wrap it up in good ol electrical tape
Old 07-31-2007, 06:20 AM   #63
bigsky2
Cousin Vitz
bigsky2's Avatar
That works too.
I have some spare t-taps if you want them. I think they're 3M, pimp stuff.
Old 07-31-2007, 06:55 AM   #64
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
That white light does look good. Maybe I'll hook them up one day.
Old 08-02-2007, 11:17 AM   #65
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
I still not install this things as I found it is not fit for yaris
Also it is flashing in blue color
damm.... not worth to spent money to spray it
jimcat is offline   Reply With Quote
Old 08-02-2007, 02:38 PM   #66
bigsky2
Cousin Vitz
bigsky2's Avatar
jimcat:
The light cluster looks BIG for that mirror. Are the blue lights LED or bulbs?
Why does it not fit? The clips don't match with the mirror assembly, or ??
Old 08-02-2007, 05:24 PM   #67
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Those are the crap thats still going on ebay....and they still dont fit unless you use duct tape.
Old 08-02-2007, 05:34 PM   #68
Canuck
Drives: 07 5 door Hatchback
Originally Posted by reggaetonfreak View Post
im gonna get rid of my side markers with this mod, lol, is way better
You do realize that the side markers let the idiot in your blind spot know that you and to turn andthat mirror won't achieve that right?
The side markers are a safety thing.
Canuck is offline   Reply With Quote
Old 08-02-2007, 09:40 PM   #69
Yes but strangely enough, go look around at pics of the stock USDM sedan... no side markers!
Old 08-02-2007, 11:12 PM   #70
Canuck
And a lot of US cars still have red rear turn signals that are impossible to see, What's your point?
Old 08-03-2007, 06:35 AM   #71
Violin
Violin's Avatar
But you can see the front turn signals on the sedan from the side:
Not so with the liftback.
Old 08-03-2007, 09:05 AM   #72
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Originally Posted by bigsky2 View Post
jimcat:
it was LED light, but slightly not fit for the mirror, without any screw hole to fix the mirror assembly. so i dont know how to do.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 10:58 PM
