#19 | |
Absolutely Red!!!
Drives: 07 A/T Yaris Liftback Join Date: Mar 2007
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
I normaly gas up before "O Shit" light, but tried out my new 07 LB just for personal satisfaction. When the lights started to blink I burned 9.3 gallons. So, if the 11.1 capacity is correct I still had a little bit to go.
#21 |
I think it's most important to not let the fuel ever run out completley. I don't know if it's true for the Yaris, but many fuel pumps, especially diesels, use the fuel as a lubricant, and when you run out you are running a pump without lube. I've never heard the fill up a 1/4 tank thing, and I've never had to replace a fuel pump. I think that's more of a safety issue recommendation; don't want people running out of gas on busy streets.
Back on topic, my blinking light works great. It starts off relatively slow and steadily increases to a rapid blink. The most fuel I've ever put in after the rapid blink was 10.68 gallons. It holds 11.2 so I got pretty close to empty. That was 27 miles past the beginning of the blink. |
#22 |
Yaris my baby
Drives: Yaris Hatchback 2007 Join Date: Aug 2007
Low fuel light
I have a 2007 yaris M5.
Concerning the fuel level display: I know that the last square starts to flash when you reach it on the elctronic fuel level display. But does the gas tank light up when you are real low? I looked in the manual but it doesn't specify. thanks! |
#23 | |
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Do you mean is there a gas pump icon that appears? No. That one rapidly flashing light is all the warning you get.
Bringin the Bling to Yarisworld |
#24 |
Yaris my baby
Yep i meant gas pump icon lighting up,blinking ,etc
Glad u got a laugh out of it though. |
#25 | |
By the way when did Toyota start making M5s?
#26 |
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7 Join Date: Jul 2007
if u read that little book that came with your new car it would inform you that the last bar in fuel level display starts blinking slowly at 1st and speeds up the blinking the lower your fuel level gets..
SOO when it's blinking like a Cop on yer ass for speeding, your about to run out of fuel ... also bad things can happen if you run out of fuel , some of which are not what is talked about below NOW here's the rub , You should NEVER ! & i do mean Never ! let your fuel level get to the point of blinking .. WHY you ask ? the fuel pump is electric & is located in the bottom of your fuel tank . The fuel in the tank keeps the motor & pump assy. COOL as in not overheating while in a bath of cold fuel , when real low on fuel this exposes the fuel pump to air & air don't dissipate heat very well inside a closed fuel tank If your one of those types that let's it run all the way down to a flashing bar, "I ani't got the time right now to fuel" on every tank of fuel . then a replacing the fuel pump assy chore is in yer future AND it's NOT CHEAP to replace it , as the pump assy is very expensive & the labor is even more (they have to drain & pull the fuel tank off to get the pump out ) not to mention the tow bill Soo to all you BUZI people out there in YARI land , who don't have the time to fuel when you got 2 bars on the fuel display , all that fuel & money yer saving getting out of your Yari at 40mpg is going to the guys replacing the fuel pump .. been there, done that , didn't even get the TeeShirt from the service dept. the tow truck driver asked me if i let run down all the time , i say yes, he laffs & looks out the window the service dept. manager asks the same question ,he just nods when i say yes I finally ask why do i keep getting asked the same question about low fuel when i picked up the car .. this was after the mind numbing shock of the HIGH service bill ! Warranty HAH ! not if you say yes to the above question , as they call it abuse I'm L O L now but it was not Funny at the time !!! |
#27 |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
Actually, if you take a glance under your car right before you fill up, your tank will have a slight luminescence to it...
It's scary to think that half the people surrounding you are below average...
#28 | |
![]() ![]() Drives: 07 BB Yaris Join Date: Aug 2007
#29 | |
but then agin if i was in his shoes i'd done the same ,he makes money off stupid people doing stupid things .. Ya don't educate yer money makers
#30 |
i try to fill up the tank when i'm at 2 bars.. only once did I do so at one bar. since i'm so good about fillin' up, my car hasn't glowed yet
Don't Milk the Cat! -Said by me during a game of Cranium.
#31 |
![]() ![]() ![]() Drives: Black Yaris YRS 3dr Manual Join Date: Aug 2007
well u learn something new everyday! good thing i havent gotten my yaris yet so its not too late :D hehe
#32 |
![]() Drives: 2007 Yaris LB Met. Meteorite Join Date: Jul 2007
Sweet Christ... I've only had 6 fill ups so far on my Yaris, and all but once went down to the blinking bar. Glad I read this post, as that will never happen again...
#33 |
![]() Drives: 4x4 EGG Join Date: Aug 2007
blah...I just recently put gas in my Yaris for the first time. I let it get down to the blinking bar...then the blinking bar started blinking FASTER. so i was like ok NOW ill get some gas. so when I went to fill it up, it only put in 10 gallons meaning I still had a good gallon or so still left in the tank! I was pissed because I could have kept going lol. Im wondering if you let it go far enough if the blinking bar will just disappear entirely. Ill try to test this at the end of this tank :P And Im not worried about the stupid pump failing.
Garage: '00 Phoenix Yellow Integra Type R Turbo '07 White Nismo 350Z '07 Yaris LB |
#34 |
der Zeck
this was a repost..... so I was kind enough to merg the post so you do not have to click any links or day any searches to see what ppl had to say about this subject b4
#35 |
You give so much to us everyday Black Yaris. We are grateful.
#36 | |
Mr Attitude
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 12:02 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
| Fuel low light issue | Kitt | DIY / Maintenance / Service | 3 | 03-22-2007 01:44 PM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
| rear fog light and tuned rear lights | lefti696 | Cosmetic Modifications (Exterior/Interior) | 0 | 11-09-2006 03:06 PM |
