Old 10-31-2008, 04:02 PM   #109
richardholdener
Drives: 2008 Yaris hatch
Thanks Rockland for the insight on the previous post regarding con rods-it is appreciated. Piston slap, offset crank pins-where do these guys come up with this stuff? I can remember when the light clicked on for me, the day that I realized that I didn't know everything and in fact knew very little. That is the day I officially started learning. Unfortunately, people put forth much more effort convincing others of their knowledge than actually obtaining it. For the record-Rod failure is caused by tension loads (rpm), extreme compression loads (detonation or extremely high power levels) or fatigue cycle life (extended operation near fatigue). Since none of the other situations were present-we must suspect detonation as the culprit, but will perform a post mortem to see if there is any evidence. The 1NZFE rods do not fail by design, neither did the Honda rods or small block Ford rods or any of the many powdered metal production rods-the culprit has almost always been a tuning error. There is a limit to the power production with the production rods, but since (in the case of this yaris) we were nowhere near that absolute power limit
Originally Posted by ROCKLAND TOYOTA View Post
don't mind him, he's just our resident scion ass paper who thinks his knowledge is helpful.....
richardholdener is offline   Reply With Quote
Old 10-31-2008, 04:09 PM   #110
Tamago
Tamago's Avatar
Drives: UZJ100
so explain this:
on a stock engine, stock ecu, intake, exhaust, bone dry day (so dont' even say it was hydrolock) at 85mph (over 4300rpm) about 80F ambient temperature, engine had 47,000 miles on it.
the 1NZ is not designed to rev above 4000rpm for extended periods of time.
Old 10-31-2008, 04:12 PM   #111
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
better than being ignorant like you
ass paper.....
Old 10-31-2008, 04:16 PM   #112
Tamago
Tamago's Avatar
Drives: UZJ100
ass paper.....
hey, at least i didn't put spaghetti with bendy ends between my seatbelt bolts and call it a suspension mod ;)
Old 10-31-2008, 04:24 PM   #113
ROCKLAND TOYOTA
TRIM HUNTER
better than that video of you with the bald tires. what a waste of 5 minutes that was.....
Old 10-31-2008, 04:29 PM   #114
Tamago
Tamago's Avatar
Drives: UZJ100
you think?
a video of a car that could rape you in its sleep, on tires 50mm wider than you'll ever be able to run, with twice the power you'll ever see is worse than spaghetti and bendy ends.. that you could build from home depot or hrpworld.com for around $12... at least it's shiney with a cool sticker on it (no offense to you Garm)
Old 10-31-2008, 04:34 PM   #115
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
GENTLEMEN!!!! CUT THE SHIT
Old 10-31-2008, 04:35 PM   #116
Tamago
Tamago's Avatar
Drives: UZJ100
i'm done..
i came here to ask richard H a legit question
Rockland started it ;)
Old 10-31-2008, 04:39 PM   #117
Nexus1155
Drives: Audi
hahah sorry, but i had to intervene, don't want Richard taking away the manifolds
Old 10-31-2008, 05:09 PM   #118
richardholdener
No worries about the intake situation--and I respect people having and voicing their opinion(this is what makes America great). I just wish they would not be so quick to draw absolute conclusions from such small samples (the equivalent of automotive bigotry). One or even two damaged con rods does not mean all NZFE rods are bad. Honda guys thought this too, but since I ran stock B16s in endurance racing where we ran 8200 rpm for 24 hours, not to mention producing over 500 hp in turbo form, I'd say the weak con rod theory was just that. FYI-Engine testing at the OEM level includes running the motor for 24 hour periods and ranging the engine speed from peak torque to peak horsepower. This is done at 1/4 throttle, 1/2 throttle, 3/4 throttle and then at WOT to endurance test the reciprocating assembly. I personally have run my Yaris in 4th gear from Vegas to So Cal and back (mileage testing for my book) and run it flat out 114 mph for almost 9 straight miles. This combined with the hundreds of dyno tests run to the rev limiter under WOT shows me that (as has been their history) Toyota over and not underbuilds their vehicles.
Old 10-31-2008, 06:05 PM   #119
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Well said!
Old 10-31-2008, 06:14 PM   #120
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Can we, can we all get along?
http://www.youtube.com/watch?v=aMfr2CgIPhg
Old 10-31-2008, 08:11 PM   #121
Tamago
Tamago's Avatar
Drives: UZJ100
all that said, you threw a rod
i'm not bashing the 1nzfe. i love them so much i'm on number 2.
Old 10-31-2008, 11:50 PM   #122
Nexus1155
Drives: Audi
is the 1nz-fe sleeved like the B18....ehhhhh!!!! ;) happy halloween
Old 11-01-2008, 12:10 AM   #123
dallas
Drives: Yaris Hatch /Landrover D2
With previous dyno runs with bigger intake manifolds and throttle bodys without more displaement, more cam, or forced induction a higher flowing intake will offer very little gain and may loose h.p /torque until very high rpm.
What calculations are you using for runner diameter and length.
dallas is offline   Reply With Quote
Old 11-01-2008, 12:10 AM   #124
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
can't wait for my manifold!
Old 11-01-2008, 12:37 AM   #125
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
OoOOooOOoo. I might be one of ten with the only aftermarket intake manifold for a looooooooooong time. Nice
If the manifold turns out to be that good i'm sure Richard will be making as many as he can sell! He surely needs to recoup his R&D costs somehow.
The only way I could see a great manifold not being continued is if it costs more to make than what the market is willing to pay.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-01-2008, 01:33 AM   #126
cali yaris = "the market"
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
