Old 11-25-2008, 12:22 PM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by otterhere View Post
Wow, y'all have given me a headache; did I mention that I'm math-challenged??? It doesn't bother me; I just move with the flow of traffic anyway, keeping a safe distance behind whoever's in front of me.
Certainly not going to take it back to the dealer and complain; too happy.
but you don't want your ODO to show 20% error if you are on a lease.
Old 11-25-2008, 03:04 PM   #20
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Originally Posted by IllusionX View Post
No. It doesn't change a thing. A sales guy at Brossard Toyota (he doesn't work there anymore) did the test with 2 echos. a hatchback with factory 14" (175/65R14) and a sedan with factory 15" (185/60R15). They did many tests driving side by side... both at 100kmh, the 15" would over take the 14". The sedan would have to drive at 96kmh to stay equal with the hatch, and the hatch has to drive at 104kmh to keep up with the sedan.
The test was done to prove that toyota did not adjust the ECU to reflect the different overall diameter size of the wheel/tire.
In fact, to match the 175/65R14, you would need 185/55R15.
That's an interesting test they did.
I always thought Toyota would adjust the speedo according to the tire diameter.
I guess my speedo shows 3.3% slower than I'm actually going, but that's no problem.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 11-25-2008, 05:35 PM   #21
b_hickman11
Drives: 08 Sedan
yes but if downgraded after to 17's without resetting the ecu the speedo would be wrong
Arent the tires on the 17's smaller than the ones on the 15's? I always thought the bigger the rim, the smaller the tire.... Usually you can stand them up side by side and they will be the same height. One has more tire while the other has more rim.
Old 11-25-2008, 07:56 PM   #22
IllusionX
well then i'm not understnading something with my 195/55/15 while my speedo says 120km/h the gps says 123km/h. while on stock tires 175/65/14 the speedo is dead on. so there is an error, or am i missing something
I'm running on 195/55R15 in the summer.. and 195/60R15 in the winter.
That's interesting, i should grab a GPS to check this out again. I haven't really checked out my speed with a GPS since i'm not running on stock tire size.
And btw, we're allowed 10% error on the speedo, so I do not think Toyota would bother making another part for models with different tire sizes.
Old 11-25-2008, 08:16 PM   #23
tetzyamis
'09 5dr
tetzyamis's Avatar
To get diameter in mili meter:
Width/Height/Rim
Rim * 25.4 + Width * Height / 100 * 2
So,
175/65/14
14 * 25.4 + 175 * 65 / 100 * 2
= 355.6 + 227.5
= 583.1 mm
185/60/15
15 * 25.4 + 185 * 60 / 100 * 2
= 381 + 222
= 603 mm
And,
1 - 583.1 mm / 603 mm = -3.3%
which makes 185/60/15 to show 3.3% slower in speedo than 175/65/14.
I always thought Toyota adjusts this as PK198105 says.
But IllusionX's dealer's test shows that Toyota doesn't.
I guess I gotta find that out myself by testing mine since it came with 185/60/15.
Old 11-25-2008, 08:25 PM   #24
IllusionX
they dont but the dealer will readjust the ecu, at least my dealer does. as a rule as soon as the diameter changes the indicated speed will be different from the actual speed. therefore if your wheel diameter changes but your overall diameter (wheel+tire) stays the same or close to the original then your speedo will be ok , but if the overall diameter changes from stock then the speedo will be wrong
which dealer do you go to ?
And i just don't think the ECU is THAT flexible in reprogramming ??? Because if the dealer has the resources to do it, then other people out there can do it. At least, the mechanics has to learn how to do it, and sooner or later, the information will leak.. People will use this to ALTER their ODOMETER readings, hence illegal... ???
haha btw, PK, i posted in the Quebec forum with the question.. let's hear the answers...
Old 11-26-2008, 06:33 PM   #25
IllusionX
Originally Posted by XZR
non ta vitesse est calculer avec les speed sensor dans le centre des bearing de roues pour un vehicule avec ABS et dans la trans. si pas ABS
translation: the speed is calculated with the speed sensors at the middle of the wheel bearings for cars with ABS, and it is in the transmission for those without ABS.
sooooo........... if you are 20% off, you might want to take it back to the dealer to have them checked. Because if your speedo is showing 60mph and you are really going 80mph!~ Hmm... it could be very bad! that's 250$USD speeding ticket in Champlain, NY
Old 11-26-2008, 07:28 PM   #26
Chrsto4
Chrsto4's Avatar
Drives: 2008 Yaris RS 5-dr HB Black
Interesting thread. I just thought I was crazy because my GPS usually says I'm going faster than my speedo shows. Hmmm....I AM sane - who knew.
Chrsto4 is offline   Reply With Quote
