Old 11-24-2008, 01:41 PM   #1
otterhere
Drives: 2008 Yaris 3-door Meteorite
Spedometer inaccuracy?
Mentioned in another thread:
I'd swear my spedometer shows me going 10-20 miles faster than I'm actually going; has anyone else noticed this, or should I report it to my dealer??? Not sure how to measure this accurately except that yesterday I was just moving with the flow of traffic on the interstate (70 mph; most do 75-80 mph), and it showed me doing 90!!! Not everyone else was also driving a Yaris, either...
otterhere is offline   Reply With Quote
Old 11-24-2008, 02:15 PM   #2
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
Mine is off by about 5mph, i noticed it with my GPS, but i don't mind.
Old 11-24-2008, 02:52 PM   #3
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
Tire size will make the speedo off, but not that much off.
Let's say your original tire size is 185/60/15, to make the speedo off by 10 mph at 60 mph, you gotta put tires like 165/50/14.
I don't think tires that small even exist.
I would ask a friend to drive next to you and ask him how fast he's going.
If your speedo is off, then I'd take it to the dealer.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 11-24-2008, 03:38 PM   #4
otterhere
They do substitute 15" wheels for the original 14" when they add the packages (I got convenience and all-weather, only because I couldn't avoid them)... Could that be it?
Old 11-24-2008, 03:52 PM   #5
tetzyamis
'09 5dr
tetzyamis's Avatar
No, that will make the speedo slower, not faster.
If 175/65/14 says 50 mph, 185/60/15 would say 48.35 mph.
Old 11-24-2008, 04:23 PM   #6
nemelek
DWEED
nemelek's Avatar
Making the asssumption that the speedometer and the odometer are linked together, the odometer is easy to check using the highway mile markers.
Old 11-24-2008, 04:32 PM   #7
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
According to my scan guage my spedo is pretty much dead on. Maybe a mile per hour fast.
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
Old 11-24-2008, 04:38 PM   #8
Just as easy for speedo too. Hold constant speed between markers and time it.
Old 11-24-2008, 04:40 PM   #9
The speedometer and scanguage get their data from the same place. The Yaris' speedo is purely electronic. If you see a difference between the speedo and the SG, it is because of the SG's lag in reading and displaying data from the OBD port.
Old 11-24-2008, 08:20 PM   #10
voodoo22
Drives: Yaris Sedan (auto)
Speedometers on all cars are set to read faster than you are really going, and that's correct. Putting on 15 inchers in place of 14's would make your speedometer read about 3-5% slower depending on overall dimensions.
voodoo22 is offline   Reply With Quote
Old 11-24-2008, 08:33 PM   #11
b_hickman11
Drives: 08 Sedan
It doesnt matter if you have the 14's or the 15's. If it came from the factory then the speedometer is set using the rims on it. I had a 05 Taco with factory 20's which was an upgrade. The regular rim size was 17. My speedometer was set for the 20's.
Old 11-24-2008, 09:03 PM   #12
tetzyamis
'09 5dr
tetzyamis's Avatar
it does matter , if the dealer doesn't reset the ecu. if you change your overall diameter the speedo will be off.
Hickman said "If it came from the factory", which means dealer did not change the rim.
Old 11-24-2008, 09:13 PM   #13
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i'm about 5mph off with the summer tire/rims
Old 11-25-2008, 02:57 AM   #14
ddongbap
Are you guys taking into consideration the overall diameter of the rubber themselves? It really doesn't matter how much off the metal rims are.
Old 11-25-2008, 09:04 AM   #15
yes but if downgraded after to 17's without resetting the ecu the speedo would be wrong
No. It doesn't change a thing. A sales guy at Brossard Toyota (he doesn't work there anymore) did the test with 2 echos. a hatchback with factory 14" (175/65R14) and a sedan with factory 15" (185/60R15). They did many tests driving side by side... both at 100kmh, the 15" would over take the 14". The sedan would have to drive at 96kmh to stay equal with the hatch, and the hatch has to drive at 104kmh to keep up with the sedan.
The test was done to prove that toyota did not adjust the ECU to reflect the different overall diameter size of the wheel/tire.
In fact, to match the 175/65R14, you would need 185/55R15.
Old 11-25-2008, 09:08 AM   #16
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Mine is quite accurate.
GPS, Speedometer and SCII all show exactly the same mph. I have noticed that the GPS unit has a lag in the reading.
I am running stock tires on steelies.
Old 11-25-2008, 09:15 AM   #17
otterhere
Wow, y'all have given me a headache; did I mention that I'm math-challenged??? It doesn't bother me; I just move with the flow of traffic anyway, keeping a safe distance behind whoever's in front of me.
Certainly not going to take it back to the dealer and complain; too happy.
Old 11-25-2008, 09:31 AM   #18
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
Math is easy--> http://www.discounttire.com/dtcs/infoTireMath.dos
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
