Old 12-15-2008, 06:41 PM   #19
The aFe is a nice replacement for the stock box, keeps the filter protected while increasing airflow.
My air filter off the turbo is way down towards the bottom of the engine. We will probably re-route the piping when we put her back in the shop -- made me nervous on the way to work today.
With regards to water in the motor being dangerours, aren't there water injection systems? someone 'splain that, please.
Old 12-15-2008, 06:42 PM   #20
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
yeah thats what i want to watch now too. cuz right when i got my yaris i put on the CAI so i wasnt really able to tell the mileage with out it.
falkor_99 is offline   Reply With Quote
Old 12-15-2008, 09:20 PM   #21
i thought water injection just sprayed a mist on an intercooler to help cool the air down even more....
if your filter was drenched, thatd explain the bogging
dryflow ftw? lol
id put the fender liner back in or get a short ram intake.....stock airbox for now
i cant belive youd run a cai with no fender liner though....yeesh
Old 12-15-2008, 09:37 PM   #22
Split
Drives: 2008 Yaris Sedan
Exclamation
if the filter is soaked, it'll struggle to draw air through it. it'll struggle, but it won't hurt it.
if the filter is completely submerged in water, that's when you're in trouble. trimming the fender liner will get the filter soaked, but it doesnt make a difference for hydrolock.
Split is offline   Reply With Quote
Old 12-15-2008, 09:57 PM   #23
06silveryaris
Drives: 2006 yaris
Originally Posted by falkor_99 View Post
man.....that sucks cuz i love the way it sounds and looks.....not cool i guess ill have to do that then =( that makes me sad
You can make a hole on the stock air box if you want to make it loud. The hole needs to be on the bottom half. That is what i did to my airbox looks stock but sounds quite mean and I am using the paper filter.
06silveryaris is offline   Reply With Quote
Old 01-05-2009, 05:29 PM   #24
dvldoc
Drives: 2008
For one, Water injection works very well especially in forced induction engines. The thing that you are most likely getting is that you have gotten the MAF sensor wet and if you have a K&N style oiled filter have transferred some of that oil onto the sensor which is very sensitive.
What people fail to realize for every gallon of gas you burn you vehicle produces up to or more than that amount in water on it's own. It's part of internal combustion, and is no big secret. People tend to say all these crazy things about water simply because they do not know the chemistry behind internal combustion. If they did they would stop getting suckered into HHO generators
Even a stock Yaris could handle a .50gph water injection nozzle and would run just fine. This is coming from someone who knows a little about alcohol/water injection. Turbo it and water injection is a great way to go.
dvldoc is offline   Reply With Quote
Old 01-05-2009, 06:14 PM   #25
Tamago
Tamago's Avatar
Drives: UZJ100
atomized water will not cause issues..
but water sucked off the ground is not atomized...
Old 01-05-2009, 06:38 PM   #26
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You can clean your MAS by shooting some "Brakleen" on it. If the MAS has oil on it from the air filter it can affect performance.
Old 01-05-2009, 08:00 PM   #27
Tamago
Tamago's Avatar
Drives: UZJ100
BRAKLEEN is simply awful to be spraying on plastic parts... use soap and water
Old 01-05-2009, 09:00 PM   #28
gid
you get condensation in oil from hot engine cooling in cold weather and collects in pan . Thus , oil looses some performance .
Old 01-11-2009, 07:39 PM   #29
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by gid View Post
you get condensation in oil from hot engine cooling in cold weather and collects in pan . Thus , oil looses performance .
now for a complete change of pace. How much do you want for that dead parrot you have there. Yes the One with its feet stapled to the perch. Very, very NICE, but a bit smelly, aint She?
On yet another subject, mr GID, I thought that the piston blowby water vapour condensed into the cold oil. If the oil was above boiling for a goodly period, all the H-O-H will have evapourated off and suctioned by the PCV sytem. Now, there would be none left to condense onto cold metal.
- Papa
Old 01-11-2009, 08:19 PM   #30
gid
are you feeling o.k.? You've been a bit testy lately .
Old 01-11-2009, 08:48 PM   #31
ddongbap
- Papa
Crack that whip, daddy.
Old 01-12-2009, 12:28 PM   #32
gid
moisture in oil , especially on short daily trips .
Old 01-12-2009, 10:35 PM   #33
auxmike
auxmike's Avatar
- Papa
Dang,
Sounds like something Hannibal Lecter would say....
Old 01-12-2009, 11:48 PM   #34
gid
is that not from the " dead parrot " stick by MONTY PYTHON ? Here it is www.youtube.com/watch?v=KO1T7b07I7E .
Old 01-13-2009, 01:02 PM   #35
TheSilkySmooth
It was a (very bad) backward spin on part of the sketch, but of course, M.P. was M-U-C-H better. Also, "ARGUMENTS" and the exploding penquin on the telie.
cool about finding that
Old 01-13-2009, 01:08 PM   #36
gid
I've been having YOUTUBE seizures along with U.O.A. withdrawals ( shakes , etc. ) .
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
DIY: 10 minute engine bay detail Razr DIY / Maintenance / Service 61 07-28-2020 02:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
