![]() Drives: 2007 Black LB Join Date: Nov 2008
Where to buy and install a Hitch??
I have a 07 LB and would like to have a lightweight hitch put on to carry a couple of bikes around. Where should I go to buy a hitch and have it installed. Having never bought a hitch before I am not sure where to go to have it done (auto dealership, muffler shop, car rental, etc). I am assuming that some places will be a lot less than others.... but not sure which. Also, any idea to approx costs of installation. Do you normally buy a hitch and take it in for installation or do you buy from the shop that installs it? And any specific hitch suggested.
-Much appreciated. |
#2 | |
http://www.etrailer.com/products.asp...chback&ob=&so= This link is directly to the ones that they carry for the 07 Yaris LB. The installation on the Yaris is quite simple (four bolts, which go into existing holes in the frame end panel). Most guides say that you don't need to remove the rear bumper skin, but doing so gives you much better access to the frame end panel that the hitch mounts to. |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
You can get a DrawTite or HiddenHitch from an on-line retailer like AutoAnything.com and put it on yourself. The better designed ones such as these make use of existing bolting points and just replace the bolts with slightly longer ones.
The only problem I had was one of the bolts was impossible to get a wrench on once the hitch bar was in place. I ended up putting the bolt in from the other side and putting a locking nut on it. The hitch itself is about $120 for a good one. With mine I carry a bike rack or a lightweight hitch basket. You shouldn't put more than 150 lbs of gear on a Yaris hitch rack or basket, but that can still be plenty to get coolers or other large items out of the interior. For a temporary solution, you can get 2 bikes in the hatch with the rear seat down. Particularly if you take advantage of quick release front wheels and just lay them carefully on top of the bikes. |
uhaul.com part number 249060
$140 or so.. that's for a sedan though
Drives: Yaris Liftback Join Date: Nov 2008
I have a Hidden Hitch on my 07 LB. Same purpose as yours, to carry bikes. Put it on myself with no problems, but the top bolts are a bit of a pain. Nice clean look.
Hidden hitch is the definitely way to go, invisible when not in use...
I recall seeing a couple different types on eBay but don't recall whether HB or Sedan.
Thanks to All for great comments. I think I am leaning towards the Hidden Hitch so I can use existing bolt holes. My only question is.... Did I read somewhere where sometimes you have to file off part of the bumper fascia to make it fit?? Or maybe I had a dream.
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
autoanything.com , had mine for <$100 2 days after ordering. no modifications to mount, just had to bolt it on.
hidden hitch brand btw... pulls my motorcycles (one at a time...) on a 4x6 trailer quite nicely... |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I ordered one from u-haul and the part numbers shows as "24821"... which googles to Pontiac G8 hitch.
Will it fit just the same as 24819? |
| Best Buy did a hack job on my component install...... | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 02-15-2009 10:45 PM |
| Help me install my Infinity Basslink! | wsladaritz | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 10-21-2008 12:15 PM |
| Help me install a converter to HU | wsladaritz | DIY / Maintenance / Service | 8 | 09-07-2007 06:54 PM |
| Install a Yaris deck into a Matrix... bad idea?? Help needed!! | SimmZ | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-17-2006 01:01 AM |
| Getting ready to install a new system | mather28 | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 11-12-2006 07:03 AM |
