Old 08-31-2007, 09:16 AM   #1
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Question Help me install my Infinity Basslink!
I just recently purchased my Inifinity Basslink off amazon for $200 and it should be getting it early next week. I talked to a guy at Best Buy and kinda got the details on how to hook it up, but after trying to install my old bazooka tube in a friends truck and failing miserably, I am not so confident in myself anymore. I do not want to pay Best Buy to do it though. I bought an adapter that converts the speaker wire output into RCA that I can run back to the sub.
I know there is going to be a ground wire... if I'm putting it behind the back seats in my hatchback where is the best place to put that? Anywhere metal?? ( like under the spare tire maybe?)
I know there is going to be a power wire and I'll connect that too the battery.
The bazooka tube had a blue wire that I was told needs to be connected to an auxillary power source that will switch it on when the car comes on? **About the bazooka real quick... My dad helped me install it in my old car. I just took it out... and then put in my sisters car with the same head unit. I don't know what to do when trying to hook it up with the head unit in my friends truck. That's another story though. **
THE BLUE WIRE... or aux power or w/e it is. Where would be the best place to put that?
Anything that anybody has to say about this that can help me out makes you the coolest person in the yarisworld.com! pics of what your talking about would be very nice also since I am not very mechanically or electrically inclined :)
THANKS!!
wsladaritz is offline   Reply With Quote
Old 08-31-2007, 11:15 AM   #2
punch
punch's Avatar
well, depends what deck your using; is it the stock deck????
if using the stock deck, you can wire the "blue" wire into the cigarette lighter wire, or even tap into it at the fuse box's cigarette fuse location. ( they sell a fitting to do this), basically anything that only gets power when the car is in run.
if using an aftermarket deck, it will have either a power antenna wire, or a "acc" wire which you would connect to the blue wire...
power wire, yep connect that to the battery, ground yep, find a nice bolt and remove it, and secure ground wire ( best way is to strip some paint off the body/frame, and screw your ground wire down...)
out of respect for nutzoid, I changed my avatar.
Old 08-31-2007, 12:21 PM   #3
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
how would you hook up an aftermarket amp to run a small subwoofer... I remember in my car i had to buy a converter and tap off of the lines.... is that the same concept?
Old 08-31-2007, 06:36 PM   #4
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
Right, but most after market decks have those Sub RCA's outputs so no need to tab into nothing. they also have a connection for that blue wire.
for the question with the blue wire tap into the lighter fuse if using a stock deck.
then make sure you get a good converter when tapping into any speaker wire believe me it makes things easier and it sounds a whole lot better.
Old 08-31-2007, 10:36 PM   #5
Nexus1155
Drives: Audi
got a wiring schematic for the speaker wires?
Old 09-01-2007, 02:10 PM   #6
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Cool, I guess I have it all figured out then. Thanks for the input guys! Should be a breeze installing it when I get it in the mail :) And yes, I am running the stock head unit. And stock speakers.
Old 09-01-2007, 09:24 PM   #7
punch
punch's Avatar
you really should start your own thread with these questions, and the digrams are posted on this site...
Old 09-01-2007, 09:31 PM   #8
Nexus1155
Drives: Audi
i will when i finish fiberglassing my box and i will be like hey peoples look at me mr ill fiberglasser and than someone will be like FS:? and ill be like nah.... maybe... hahaha in due time
Old 09-05-2007, 04:57 PM   #9
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
QUESTION!!! Where would be a better place to install this Infinity Basslink.... on the back door ( hatch, or w/e u call it ), or on the floor behind the back seat?? Or somewhere else... though I don't think it will fit anywhere else. Suggestions? Ideas?
Old 09-07-2007, 01:59 AM   #10
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
GOT IT!!! And it sounds AWESOME!! I am very extremely pleased with it! Didn't need the converter. The infinity basslink comes with 4 speaker wire inputs that I spliced with the existing speaker wires. This helped alot:
http://modifiedlife.com/stereo-radio...-toyota-yaris/
Old 10-19-2008, 07:25 PM   #11
sanityassassinv2
The poison in your poison
sanityassassinv2's Avatar
Drives: 2008 Black Liftback MT
I'm very happy with the Infinity Basslink. It's not going to win any competitions but it is a great compromise between ease of install, size, and sound. It provides enough bass to put a smile on my wife and make the mirrors rattle with vibrations.
I installed it on the left side so I could run power down the left side of the vehicle and the audio on the right...most of the cars power wires are on the left side of the vehicle, so installing it like this should minimize hum. You also have easy access to the controls of the unit when it is installed like this.
Since I don't have power mirrors, I used the spot reserved for mirror controls for my remote volume knob. I also cut a small notch in the cover over the cargo area so it operates normally. Seats still go down and I can still access the spare tire compartment with no problems.
sanityassassinv2 is offline   Reply With Quote
Old 10-20-2008, 12:21 AM   #12
FcukThis
Drives: yaris
Clean, i likey :]
FcukThis is offline   Reply With Quote
Old 10-20-2008, 12:56 AM   #13
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Looks good and stock.
bdc87 is offline   Reply With Quote
Old 10-20-2008, 01:57 PM   #14
sanityassassinv2
Thanks for the comment...it sounds good too!
Old 10-20-2008, 07:36 PM   #15
daburrrninator
Drives: 08' Sedan
Where did you pass the power cable through the firewall?
daburrrninator is offline   Reply With Quote
Old 10-20-2008, 08:33 PM   #16
sanityassassinv2
I routed the cable through an usused grommet on the right hand side of the firewall, just behind the ECU. It comes into the cabin adjacent the the air/conditioning "stuff." Supposedly there is also an unused grommet behind the battery compartment but it is difficult to get to and I didn't have a lot of free time to look for it the night I installed this.
I just went outside (whew, it's 40 degress tonight) and snapped these pix for you. I have a Liftback, so I'm not sure if the Sedan looks the same. The grommet is the one that has high-temp RTV on it, which I covered it with just in case any water tried to make it's way through.
Old 10-21-2008, 12:00 PM   #17
daburrrninator
Drives: 08' Sedan
Thanks for the pics, I'll be taking a look before I drill today. I found that grommet behind the battery, and it is not easy to get to, at all. My hand barely fits through enough to feel it. and I can even stick my finger through it, but I cant get a cable through that. Hopefully I have the same grommet as you.
Old 10-21-2008, 12:15 PM   #18
sanityassassinv2
Yeah, I felt that same grommet and even took and the battery and said, "screw this!" If you have the same grommet behind the ECU (I think you should), just pop it out and drill a small hole in the middle of the rubber...I probably didn't have to put RTV on it because I doubt moisture was going to get through it (it was a snug fit)--I'm just anal retentive like that sometimes.
Powered Subwoofer Choice??? blacksan In Car Entertainment + Electronics (audio / video / alarm) 15 09-09-2007 11:50 PM
infinity basslink mini-review tekmoe In Car Entertainment + Electronics (audio / video / alarm) 11 02-07-2007 11:41 PM
Stereo Install 07typeS Photo-Video-Media Gallery 0 01-18-2007 09:18 PM
Getting ready to install a new system mather28 In Car Entertainment + Electronics (audio / video / alarm) 2 11-12-2006 07:03 AM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
