![]() ![]() Drives: SLOOWZ Join Date: Aug 2006
Questions about springs
Would like to ask ..
is that changing the springs but not changing the whole suspension would shorten the life of the factory damper? how long will that be shorten if thats true? i wanna get kings spring due to its cheap in aust |
You can get Tanabe springs from Jay at C2AUTO or P.M. him at C2AUTOSPL. Dont know about the shipping though. Tanabe states that their springs are fine with the stock shocks and struts. I am sure it will wear a little faster depending on how far you go down, but I would be sure to get the front end aligned or checked after lowering to make sure every thing is ok.
![]() ![]() ![]() Drives: 2k3 Cavalier & 2k2 Echo Join Date: Aug 2006
Lowering springs on stock shocks/struts will shorter thier life by the half.
2003 Chevy Cavalier Ecotec - His car! 2002 Toyota Echo Sedan - Her car... FOR SALE! |
![]() ![]() ![]() Drives: 00 itr Join Date: May 2006
there is no direct amount that the springs will shorten the life of dampers. i would not worry about it too much though, by the time your stock dampers begin to fail there should be plenty of "improvements" on the market to replace them with.
I imagine the stock shocks/struts wouldnt last that long in the first place.
I can't say how long they'll last, but they do get VERY hot after a session at the track running R-compounds !
As mentioned, the Tanabe springs aren't so much stiffer than stock to cause "excessive" stress to the shock/struts... For normal street driving they should last a few years before any major signs of wear. |
Talked to Tanabe direct a few times already... their DF210's were designed to use the stock struts/springs, and factory sway bar end links.
Now you can always improve on the factory stuff, and get a much better upgrade, but its not needed. |
For the DF210's you guys mentioned,will it drop the baby?
#9 | |
#10 | |
![]() ![]() Drives: '00 s2000, 2007 yaris hatch Join Date: Jul 2006
happy motoring!
| TANABE SPRINGS | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 11-20-2008 07:38 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 12:28 AM |
| FS: Spirit Lowering Springs 1.7" drop | xCookiE | Items for Sale by private party | 2 | 07-24-2006 08:29 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
