![]() Drives: 2008 YR 5 door Join Date: Nov 2008
Proper offset?
Hey guys, i am looking at 17's for my yaris hatch, YR, The rims i am looking at are a 4x100 with a 42 offset, basically want to know if this is the correct offset for the car...
The Mach-10's http://www.tenzoracingsports.com/main.php?page=wheels |
Yup, ET42 will work just fine. Some nice wheels there. Which ones do you plan?
not 100% sure yet, but looking these 3.....
Those 3 styles are nice. I'm partial to the mesh and multispoke designs. Hmmm... I guess the mesh win out for me.
all the rims come in 17" in a 4x100 configuration with a 42 offset, won't fit?
Yes. 17x7, ET42, 4on100 will do just fine. Run 205/45/17 on stock suspension or with a mild drop.
on stock suspension or with a little bit of camber, you can easily run a +35 offset.. it'll give you a very nice flush look. 205 tire MAX though.
#8 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
EDIT: why did you choose tenzo if you don't mind me asking? |
#9 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
I run 17x7 +18 front and +5 rear.... with 205/40R17.... I am lowered 3 inches, no rubbing problems.
#10 | |
l33t3st Asshole
does the OP? ![]() I run a 15x7 +35mm on my YARIS and it rubbed when lowered until we put coilovers on. I have a feeling that's a little more applicable then your scion when regarding the OP's setup. Although I could be wrong.... |
der Zeck
well you were commenting to Tamago.... also a Scion owner
#12 | |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Yaris + Low offsets = Rub. I rubbed with a 15x6.5, +38, and 205/50/15s I rubbed badly with a 16x7, +37, and 205/50/16s Heck, I even rub a tad bit with +40 and 195/55/15. Granted, my front end is pretty low, but not that low.
Subcompact Culture: The Small car blog |
l33t3st Asshole
who was commenting about the OP. come on, I know you're smart enough to realize what's happening here.
Main reason I replied to Tamago is b/c HE KNOWS the +35mm will rub when lowered (he was there when we rubbed the first time with our +35mm). he also knows that a +23mm 15x7 doesn't rub on stock height but pokes a good amount on a YARIS (they were his wheels we used to test). I wasn't trying to say he's wrong, b/c he isn't. He simply left out a small portion. :) |
#14 |
I'll have to say the Yaris is definitely the fussiest car I've owned with regards to offsets and lowering.
#15 |
To avoid rubbing problems with 205's, go with ET42 or higher.
Of course, on stock suspension you can run lower offsets... but the front set-up will poke and look like shit. Like 39 says, this is a very fussy car for proper fitment. But, if you want the one-size fits-all American look, then go for it. |
#16 |
i believe he was commenting on my comment about running a +35 on a yaris.
i personally run +23 front +(13) rear
#17 | |
#18 |
i recommend Team Dynamics (the racing line, not the "street line") an excellent UK-made wheel and comes in decent offerings for width and offset. simple designs, strong, and relatively lightweight
| Offset and lowering on 205/45/16s | driver centric | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 08-13-2016 10:09 AM |
| How to determine proper wheel offset? | Yaris Revenge | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-23-2009 10:41 AM |
| offset... | Keymaster | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-01-2007 01:53 AM |
| max width and offset? | Fat Felixxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 06-08-2006 03:43 PM |
| Max offset | riceboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 05-01-2006 09:57 PM |
