Old 01-18-2007, 01:49 PM   #19
ChinoCharles
Drives: LB
Sounds like fun. I engine brake a lot too. Its like a game... "See how far you can drive without using your brakes!"
Old 01-18-2007, 01:52 PM   #20
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Originally Posted by Galavoxx View Post
... Depending on how light the flywheel is made, it can make the car very unconfortable to drive. Throttle can be very revvy, some say twitchy. Of course, on a car with only 100 or so horsepower, it probably wont be that severe.
I'm hoping to get a lightened flywheel at some point... maybe a year or so from now. I'm hoping it might negate some of the effects of the drive-by-wire throttle where the revs stay up after you take your foot off the gas to shift. Either way, this car's clutch already took a fair bit of getting used to... a lighter flywheel will definately require you to have skill to shift smoothly!
2006 Red Blitzed RS 5-door
Old 01-18-2007, 01:53 PM   #21
gr8yaris
gr8yaris's Avatar
Drives: 07 Yaris Hatchback
Originally Posted by graywolf_14 View Post
Or if it looks basicly like a stock one dont say a dang thing.
Statement ^^^ doesn't make sense.
2007 White Liftback 5-speed
Tanabe DF 2" lowering springs, 205/50-15 on 15x6.5 Konig Helium, TRD rear sway bar, 15mm Hub spacer
http://picasaweb.google.com/USAntonio/MyGarage#
gr8yaris is offline   Reply With Quote
Old 01-18-2007, 01:57 PM   #22
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
haha. I love that game!! Drives my gf crazy when I grab a huge downshift on the highway and then just coast at high RPMs instead of braking. A lighter flywheel would really help in actually slowing the car. For such a small car, the Yaris just wants to keep going and going. The flywheel must be massive!
Galavoxx is offline   Reply With Quote
Old 01-18-2007, 01:58 PM   #23
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Do you guys still blip the throttle when downshifting? Or let out the clutch slowly and let the revs climb themselves?
Old 01-18-2007, 02:02 PM   #24
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Just thinking... a big flywheel will help increase gas mileage. If the engine keeps spinning with all that stored energy from the flywheel, it doesn't need as much gas to keep going. Probably why there's not much engine braking. :(
Old 01-18-2007, 02:09 PM   #25
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I usually don't blip unless something serious is going to happen, like a 180 degree left hander!! haha.
Old 01-18-2007, 02:46 PM   #26
Yarii
Drives: n/a
If you mean just while driving then no, it'll take slightly more energy to speed up the heavier flywheel to cruise speed, but once there, it takes basically no extra energy to keep it going around at steady speed.
You get less engine braking with a heavier flywheel because the drag of the drivetrain is being acted on by the energy stored in the flywheel's spinning mass. Less spinning mass=less force counteracting the wheels=more engine braking.
Yarii is offline   Reply With Quote
Old 01-18-2007, 03:03 PM   #27
ChinoCharles
Drives: LB
It depends... in normal driving situations I'll always give a little gas when downshifting, and I mean little. It doesn't take much on this weird DBW throttle.
If I'm... um... in a hurry (haha), I won't bother. My size 14 shoes won't allow me to heel-toe with the pedals the way they are.
Old 01-18-2007, 03:15 PM   #28
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I feel the same way about the throttle. But more importantly, it's good to hear there's another poor bastard out there with size 14s!!! Here's to bigfoot.
Old 01-18-2007, 03:29 PM   #29
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I'am kinda lost.... ehat are you talking about when downshifting ? taking curves? ..... talk to me in spanish hahaha just kidding .. but a nice explination would be nice
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 01-18-2007, 06:29 PM   #30
ChinoCharles
Drives: LB
Wait, I thought you were a street racer. You don't know what downshifting is?
Does EVERYONE in PR drive an auto?
Downshifting is when you drop down a gear for whatever reason, the most productive of which is entering a turn... you want to be in the gear that is going to put you at the optimal point in your powerband for when you're exiting the turn. If you enter a turn at 45 MPH but take the turn at 25 MPH and you're still in fourth gear, you're going to crawl off of the apex and come out of the turn slow. If you drop down to second gear before entering the turn, though, not only will you not have to brake as hard going into the turn, but you'll be in a good gear for when you're coming out. You'll exit the turn as fast as you could have.
Maybe someone with some track experience can refine this a bit.
Old 01-18-2007, 07:47 PM   #31
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
u smartass hahaha I'am beginin to like this guy u gotta love his sarcasm
Its obvious I know what downshifting is and I do it a lot its all curves here In PR we drive everything you should visit PR maybe we can teach u a thing or too hahaha And u might learn some reaggaeton dirty dancing while u are here
I was refering to the term "blip" in a post before blip terminology does it mean hit the gas? We don't use that term here
Old 01-18-2007, 10:21 PM   #32
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Ya... I meant to give the gas pedal a quick hit of gas. For example, say you're driving down the highway in 5th, then a corner is coming up... you can let your foot off the gas and start to slow down... when you get near the corner, you put in the clutch to down to downshift to 3rd... just before moving your right foot over to the brake, you hit the gas while the clutch is in to rev the engine... then when you let go of the clutch in 3rd, the revs are matched and the car doesn't suddenly slow down too much. I do it on my motorcycle... I've only recently started doing it on my car, so I'm asking how other people downshift! Always learning!
HAAHHAHAhahahahha!! AWESOME!! reggaeton!!!
Old 01-19-2007, 11:57 AM   #33
ChinoCharles
Drives: LB
I probably could learn a thing or two... about driving and about Puerto Rican women. Ooh la la.
And yes, blip means to tap the gas.
Old 01-21-2007, 05:28 PM   #34
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Last week me and some friends where asking ourselves what guy from outside puerto rico see in puertorrican women. I know what i like about them but we go crazy for women from other countries hahaha
Old 02-03-2009, 11:02 PM   #35
frownonfun
frownonfun's Avatar
found this distributor selling the Fidanza Aluminum Flywheel (part #133151) for $350 rather than Fidanza's $433...
http://www.autoaccessoriesgarage.com...wheel&selSort=
from what i understand this xB flywheel fits the yaris. not sure if it fits the 09's just yet but we'll see when it gets to my post box!!
