Old 02-08-2009, 06:02 AM   #1
phenoyz
phenoyz's Avatar
Drives: yaris
yaris timing belt
what is the timing belt of a yaris is it CHAIN or RUBBER?
phenoyz is offline   Reply With Quote
Old 02-08-2009, 06:22 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Its a chain,you'll never have to worry about it.
Old 02-08-2009, 06:23 AM   #3
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
I'm pretty sure its a chain
Old 02-08-2009, 08:45 AM   #4
GeneW
Drives: 2008 Yaris
Chain.
http://www.etimago.com/yaris/repairmanual/
Engine Mechanical - Caution: big PDF file. Valve clearance adjustment techniques start on page ten, which clearly shows the timing chain.
Gene
Old 02-08-2009, 10:07 AM   #5
craigq
Drives: '07 Yaris, '12 GLI
There is an automatic timing chain tensioner which maintains the proper tension (i.e. no tightening required). You should not have to touch it. It should be pratically "maintenance free" for the lifetime of the engine. Sure, there is a maximum chain stretch measurement that can be verified at defined intervals, but there should be other problems with the car by the time the chain needs replacing (at least in areas where salt is used as a de-icer on road surfaces in the winter).
From the Toyota website:
Originally Posted by Toyota.com FAQ
If your vehicle is equipped with a timing chain rather than a timing belt, there is no prescribed replacement interval.....For Timing Chain and Gears, there are no prescribed replacement intervals; these components should be replaced as needed.
craigq is offline   Reply With Quote
Old 02-08-2009, 02:05 PM   #6
Kal-El
Kal-El's Avatar
Seeing as how trini_per4mance (member) has not touched his in 305,000 miles, I'd say it should go the life of the car with no change or maintenance.
Old 02-08-2009, 02:09 PM   #7
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
however his 300k+ miles are 95% or more from highway freeway driving. for regular drivers like ourselves, wouldn't there be a difference? just my guess
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 02-08-2009, 06:46 PM   #8
TheSilkySmooth
TheSilkySmooth's Avatar
Ha, Toyota got us on the other end: the valves are non-adjustable, non-hydraulic, and the whole top end of the engine (cam box) will have to be torn down periodically to adjust any valve that is out of the clearance spec. I'll put up with some clacking rather than go through this $700- service befor 100K miles. BTW, timing chain tensioner are historically very troublesome. I like belts! Gee, why does a Lexus LS430 V8 have timing BELTS? Give me a couple strong belts!
Old 02-09-2009, 12:31 AM   #9
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
the automatic tensioner is there to maintain optimum tension of the chain however this still has to be checked. My dealership told me that it is good to verify and reset the tensioner every 100k. Maintenance free applies to people who keep their car until 100k.
As for triniperformance , like darkmoon said it is 95% highway driven therefore the stress of constant stop and go is not present thus the chain doesn't need to be adjusted at the specified interval.
actually guys, 65% of my driving is highway. the other 35% is city, stop and go.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 02-09-2009, 01:39 AM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by TheSilkySmooth View Post
... BTW, timing chain tensioner are historically very troublesome. I like belts! Gee, why does a Lexus LS430 V8 have timing BELTS? Give me a couple strong belts!
Not in Toyota's... And why would you prefer an expensive belt service over nothing required?
A lot of toyota engines, as well as most imports, used to use belts. Not anymore... Even the new 4.0 V6 (4-runner and FJ) and the new 5.7 V8 (Tundra) now use chains. In fact almost every new engine Toyota has uses a chain. Hell, even our 2006 Civic 1.8 has a chain...
And that's belt, not belts...
CHAINS FTW
Old 02-09-2009, 01:44 AM   #11
PetersRedYaris
http://www.toyota.com/help/faqs/serv...ing_chain.html
Model Year Engine Belt/Chain/Gear
4Runner 1990-2000 4 Cylinder Chain
1990-2002 V6 Belt
2003-2008 V6 Chain
2003-2008 V8 Belt
Avalon 1995-2003 V6 Belt
2004-2008 V6 Chain
Camry 1990-2001 All Belt
2002-2008 4 Cylinder Chain
1990-2006 V6 Belt
2007-2009 V6 Chain
Camry Hybrid 2007-2009 4 Cylinder Chain
Celica 1990-1999 4 Cylinder Belt
2000-2005 4 Cylinder Chain
Corolla 1990-1997 4 Cylinder Belt
1998-2009 4 Cylinder Chain
Cressida 1990-1992 L6 Belt
ECHO 2000-2005 4 Cylinder Chain
FJ Cruiser 2007-2008 V6 Chain
Highlander 2001-2007 4 Cylinder Chain
2001-2007 V6 Belt
2008 V6 Chain
Highlander Hybrid 2006-2008 V6 Belt
Land Cruiser 1990-1992 L6 Gear
1993-1997 L6 Chain
1998-2007 V8 Belt
2008 V8 Chain
MR2 1990-1995 4 Cylinder Belt
MR2 Spyder 2000-2005 4 Cylinder Chain
Matrix 2003-2009 4 Cylinder Chain
Paseo 1992-1997 4 Cylinder Belt
Previa 1991-1997 4 Cylinder Chain
Prius 2001-2008 4 Cylinder Chain
RAV4 1996-2000 4 Cylinder Belt
2006-2008 V6 Chain
Sequoia 2001-2007 V8 Belt
2008 4.7 V8 Belt
2008 5.7 V8 Chain
Sienna 1998-2006 V6 Belt
2007-2008 V6 Chain
Solara 1999-2001 4 Cylinder Belt
1999-2008 V6 Belt
Supra 1990-1998 L6 Belt
T100 1993-1998 4 Cylinder Chain
1993-1998 V6 Belt
Tacoma 1995-2008 4 Cylinder Chain
1995-2004 V6 Belt
2005-2008 V6 Chain
Tercel 1990-1998 4 Cylinder Belt
Truck 1990-1995 4 Cylinder Chain
1990-1995 V6 Belt
Tundra 2000-2004 V6 Belt
2005-2008 V6 Chain
2000-2008 4.7 V8 Belt
2007-2008 5.7 V8 Chain
Yaris 2007-2008 4 Cylinder Chain
For Timing Belts, please reference our "Timing Belt Recommendations" FAQ (Frequently Asked Question) to determine the maintenance interval recommendations.
Old 02-09-2009, 11:42 AM   #12
TheSilkySmooth
A Sample of one is not statistically relevant. I have 2 toyotas with chains - one only went 67K and the tesioner crapped out and the other is at 17K and still going (on REAL synthetic oil) Lesson learned with oil quality So with my sample size of 2 we are at a 50% failure rate
Old 02-09-2009, 11:50 AM   #13
TheSilkySmooth
Oh sorry I'm an old subaru guy - we have 2 belts; one for each 2 cyl bank. I made the assumption that the toyota 4.7L v8 had 2 belts also.
My question to toyota designers, especially with the thinner oils utilised today wiith low EP adds, why no roller followers on the cam tappets (ala Mitsubishi) and why "non- adjustable without a extensive tear down? Gee I could easily adjust my 2.3L chevy vega inveted bucket tappet with a hex key and only remove the valve cover
Old 02-23-2015, 09:44 PM   #14
shastatodd
Drives: 2009 RED Yaris
automatic tensioner
so, is this something i can check myself or best left for dealer/ local servicing shop?
i have 103K miles on my 09... about 70% of that is highway miles.
shastatodd is offline   Reply With Quote
Old 02-23-2015, 09:54 PM   #15
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
When you do it you will have to remove somw other parts and have to regasket it yourself. Do you have experience with verifying timing chains and general mechanical engine maintenance past oil and plugs?
Old 02-24-2015, 12:22 AM   #16
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
As a dealer tech working for autonation toyota, I have never and never seen anybody adjust or "reset and verify" timing chain tension. Leave them alone. If it ever rattle, which is 1 in a million, get it checked. But other than that, leave it alone.
ttr125fan09 is offline   Reply With Quote
Old 02-24-2015, 02:05 AM   #17
nookandcrannycar
^^^^^This. Trini, who happens to have an old post on this thread, has over 535,000 miles on the original engine in his Yaris and he hasn't had any timing chain issues.
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
Test Drive: Yaris revolution ketel0ne General Yaris / Vitz Discussion 0 08-04-2006 11:13 AM
