Old 02-24-2009, 02:06 PM   #1
detroiter
detroiter's Avatar
Effects of too much trans fluid in the case? (auto trans)
The thought kind of popped into my head and I was starting to think about it, so thought that I would make a post to see what others opinions are.
So yeah, what are some of the ill effcts of having too much trans fluid in the trans for an auto? What are some identifiable symptoms of there being too much? Etc..
Old 02-24-2009, 02:52 PM   #2
jkuchta
Drives: 2007 Yaris hatch (red)
Some fluid may be forced out of the seals.
jkuchta is offline   Reply With Quote
Old 02-24-2009, 05:48 PM   #3
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Creates a mess and creates foam on the dipstick........ But it's not as bad as having to much engine oil.....
Old 02-24-2009, 09:38 PM   #4
GeneW
Drives: 2008 Yaris
Fluid foams
Foam reduces the volume of fluid through the transmission. Foam also reduces the heating capacity of the fluid and distorts the operation of the hydraulic system that governs the shift points and reduces pressure on the clutch packs.
Lack of pressure on clutch packs and reduction in heat carrying capacity of foam causes local overheating and accelerated wear.
This causes breakdown of fluid, increased wear and deposition of clutch pack material onto the pan at the bottom of the transmission. Clutch pack material is a sign of tranny wear. In older trannies its normal, in younger ones it's a sign of concern.
Ultimately you vastly accelerate transmission wear, reduce its reliability and cause it to fail.
You pay for a new Tranny.
Gene
Old 02-24-2009, 10:59 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
I think genew pretty much covered it.
Old 02-24-2009, 11:08 PM   #6
detroiter
detroiter's Avatar
So how long would it take then for the overfill to really do damage to the trans. And you were referring to an automatic yes?
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 06:04 AM
manual trans fluid d2dailly DIY / Maintenance / Service 65 02-14-2009 07:38 AM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
