Old 08-06-2007, 02:11 PM   #1
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
manual trans fluid
did a search for 2 hours didnt find the weight i need... i am sqitching to amsoil trans fluid and correct me if i am wrong but it is 2 quarts right?
d2dailly is offline   Reply With Quote
Old 08-06-2007, 02:20 PM   #2
d2dailly
Roar?
please???
Old 08-06-2007, 02:53 PM   #3
xpeteyjtx
Drives: 07 BB Yaris
It should be in your manual, homie. You can also find a .pdf copy of the owners manual at http://www.etimago.com/yaris/repairmanual/
Manual Transaxle
Oil type: API GL-4 or GL-5
75W-90
2 quarts or 1.9 Liters
xpeteyjtx is offline   Reply With Quote
Old 08-06-2007, 02:57 PM   #4
nqd
Drives: 07 Yaris LB Absolute RED
hey x what part of mass you from?
v
nqd is offline   Reply With Quote
Old 08-06-2007, 02:57 PM   #5
xpeteyjtx
Drives: 07 BB Yaris
Taunton, I go to school in Boston though... but I am on break right now
Old 08-06-2007, 04:50 PM   #6
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
Im in Spfld MA!! NQD + MASS FTW!!
AlphaFox is offline   Reply With Quote
Old 08-07-2007, 01:25 AM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
I want to switch my fluid as well, but I feel dumb, and do not know where to fill it back up at..... it is the only reason why I have not done it yet
Old 08-07-2007, 10:28 AM   #8
socko
Drives: 07' Liftback, man., Bayou Blue
fill hole
Black Yaris:
The fill hole can easily be seen standing in front of the car and looking down in the engine compartment to the right (driver side) of the engine. On mine, both the drain and the fill hole have a while adhesive tag on them.
I, too, plan to change to Amsoil 75W90 synthetic.
socko is offline   Reply With Quote
Old 08-07-2007, 10:35 AM   #9
Black Yaris
der Zeck
Originally Posted by socko View Post
Black Yaris:
What? a while adhesive? the drain is just like a normal oil pan
Old 08-07-2007, 10:55 AM   #10
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
I am trying to get you guys a screen shot, but the putter is not behaving. Just go to the manual sticky (C50 Manual Transaxle, P 12) for the filler and drain plug location. It does not make a lot of sense until you visually inspect the vehicle in comparison to the diagram. You can use a funnel with a long hose to fill it from the top.
YES, I finally got the dam thing to work!
blacksan is offline   Reply With Quote
Old 08-07-2007, 11:10 AM   #11
blacksan
blacksan's Avatar
BTW, here are a few more specs that I scrounged up which covers most often maintained items.
2007 TOYOTA YARIS 1.5L 4-cyl Engine Code 1NZ-FE
FILTERS
Oil Filter........ EAO09 AMSOIL Ea Oil Filter
Oil Filter........ 51394 WIX 51394 Oil Filter
Air Filter........ 49104
TRICO WIPER BLADES
Driver: NEOFORM (T16260) EXACT FIT (T261) WINTER (T37260) OKTANE (24)
Passenger: EXACT FIT (T141) WINTER (T37131)
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
All Temps......5W-30
Manual Transmission,.....GL-5
All TEMPS......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,.....GL-4
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission.....WS
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
CAPACITIES
Engine, with filter..........3.9 quarts[1]
Cooling System, W/ MT Initial Fill..........5.1 quarts
Cooling System, W/ AT Initial Fill..........5.0 quarts
Automatic Transmission, Initial Fill..........2.7 quarts[2]
Automatic Transmission, Total Fill
U340E..........3.1 quarts
Manual Transmission, ..........4.0 pints
1. After refill check oil level.
2. With ENG at operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....28 ft-lbs
Manual Transmission
Fill Plug.....29 ft-lbs
Drain Plug.....29 ft-lbs
Old 08-07-2007, 03:06 PM   #12
Black Yaris
der Zeck
I am baffled, I see where that drain plug is..... but then why do I have a drain plug in my tranny pan? Yes I drive a manual
Old 08-07-2007, 03:11 PM   #13
YarisGuy
Drives: 2006 Yaris
Thank you blacksan, very useful information.
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 08-07-2007, 04:01 PM   #14
blacksan
blacksan's Avatar
Hmmm, I need to double check as I did not notice a drain plug on my pan??? On my last Toy truck I also had duel drains and no one else with the same setup did???
Old 08-07-2007, 04:04 PM   #15
Black Yaris
der Zeck
I seem to remember Chino calling me the first time he changed his oil asking me which drain plug he needed to pull..... so I know I am not the only one..... or it is just an Ohio Yaris thing
Old 08-07-2007, 04:12 PM   #16
blacksan
blacksan's Avatar
Ok, mine also has duel plugs. I made a few calls and was told that pulling the pan plug (lowest point) is sufficient after heating up trans. I drained via vacum pump and did not bother with the drain plug as it was at only 5K.
Old 08-14-2007, 09:53 AM   #17
socko
Black Yaris:
typo, I meant to say a "white" adhesive tag.
Old 08-14-2007, 10:11 AM   #18
nsmitchell
nsmitchell's Avatar
It must be the new manual trannys, but in all the manuals I've ever done, I just used a normal motor oil like Mobil-1 10W-30. They all shifted like a dream! 75W-90 is some thick stuff. I wonder why it needs to be so thick?
Get YarAss in gear!
RIP - Casey Tatum
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
The Toyota Authorized Repair Manual. LoudYar General Yaris / Vitz Discussion 3 03-29-2007 12:20 AM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 06:09 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
