#73 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
If I was lucky enough to live in FLA, SoCAL or DownUnder, I'd be running Straight HD 30, absolutely NOT a winter oil. VI improvers are not lubricants and are the leading cause of varnish and sludge and shearing out of grade. Our engines do not take kindly to varnish and are not THAT easy on oil given they have: the dreaded flat tappet cam, hydraulic cam phasing, timing chain and guide and a hydraulic chain tensioner.
#74 |
My 145 dollar 3.5HP briggs lawn mover is still alive after 19 years having only summer use, 30wt hdeo oil fill with OC every OTHER year. Burns no oil, doesnt knock. It has NO oil pump, just splash lube. OK thats my 300th post. WEEEeeee!
#75 |
I run the Motul 300V 5W-30, and love it. This oil is designed for Le Mans....3-4K miles at full speed with no oil changes...I think it's more than enough for the street, and great for track days.
#76 | |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Motul 8100 X-Max The specifications seem similar - 100% synthetic, ester based, 5w30..
#77 |
#78 |
JDM yO!
Anyone know how the 1NZ-FE would run with 5w40?
Would it be too thick for the little engine?
#79 |
![]() ![]() Drives: yaris Join Date: Oct 2008
after u change oil, is there something you need to "reset"?
like a honda or bmw you need to reset something.
#80 |
#81 |
JDM yO!
Does anyone run 5w40 oils in their 1.5L Yaris?
| Royal Purple Transmission Fluid | caveatipse | DIY / Maintenance / Service | 14 | 01-09-2010 03:02 PM |
| Aside the name,y is Royal Purple purple? | Yawesh | General Yaris / Vitz Discussion | 6 | 01-10-2009 06:50 AM |
| AMSOIL vs Royal Purple | IllusionX | DIY / Maintenance / Service | 44 | 12-02-2008 12:35 PM |
| Royal Purple FTW | Nibs | DIY / Maintenance / Service | 11 | 09-28-2007 01:06 PM |
| Anyone familar with Royal Purple synthetic oil? | Yaris_Fan | DIY / Maintenance / Service | 34 | 06-23-2007 12:29 AM |
