Old 06-09-2007, 12:16 AM   #1
Yaris_Fan
Yaris_Fan's Avatar
Drives: Liftback Auto
Anyone familar with Royal Purple synthetic oil?
do you recommend it for a Yaris?
Yaris_Fan is offline   Reply With Quote
Old 06-09-2007, 01:19 AM   #2
i think most synthetic users here, including myself, use Mobil 1. i remember someone here saying that RP had some issues with the correct oil weights...
Old 06-09-2007, 08:31 AM   #3
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
The Royal Purple does not fair as well as some others in testing. I think most use Mobil 1, but I am Amsoil user. Just make shore you get good quality filters and not your average junk.
blacksan is offline   Reply With Quote
Old 06-09-2007, 10:49 AM   #4
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
i've used royal purple very much in the past... i would only use it on the yaris if its a high milage monthly commuter.
i don't consider mobil 1 as a synthetic its a group III oil... they mislead you and charge you more then a better oil... if u want true synthetic... get amsoil or redline...
my car came with mobil 1 in the crankcase from the factory and thats as far as it will go
Toyotech is offline   Reply With Quote
Old 06-09-2007, 10:53 AM   #5
blacksan
blacksan's Avatar
Mobil 1 Extended Performance is what all Mobil 1 oil should be.
Old 06-09-2007, 10:56 AM   #6
ChinoCharles
Drives: LB
I use Royal Purple now and won't use anything else for the life of my car.
Old 06-09-2007, 11:29 AM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Chino won a lifetime supply on The Price Is Right!
SPONSORED BY
Old 06-09-2007, 11:31 AM   #8
blacksan
blacksan's Avatar
If ya use Amsoil a lifetime supply with filters would fit in your boot.
Old 06-09-2007, 06:29 PM   #9
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
http://www.animegame.com/cars/Oil%20Tests.pdf
Royal purple at the bottom.
Motorhead6T5 is offline   Reply With Quote
Old 06-09-2007, 11:22 PM   #10
Yaris_Fan
Yaris_Fan's Avatar
Thanks for the replies.
Got my first oil change today and went with Castrol GTX dino.
Old 06-10-2007, 08:29 PM   #11
miniboon
sXe
Drives: 2007 Flint Mica Yaris Sedan
i use RP in all my cars, and love it
miniboon is offline   Reply With Quote
Old 06-10-2007, 10:09 PM   #12
keesue
Chillin' out by the Bay
keesue's Avatar
What weight do you use, Charles?
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 06-11-2007, 05:51 AM   #13
Nigal
Nigal's Avatar
This stuff is like $80 a gallon? Sweet Jesus! Even DIY I'd go broke running it in my car.
Old 06-11-2007, 09:05 AM   #14
ChinoCharles
Drives: LB
I use what the manual recommends. 5W-30 right? Its early and I can't think but I'm pretty sure thats the magic number. May switch to a lighter weight soon to see if those MPG gains are for real. 1500 more miles until 20,000.
Nigal, since the Yaris only takes 3.9 quarts of oil there should be no reason not to use the best oil possible. I picked up 4 quarts at Summit Racing for $26. That is less than I'd pay the stealership to put dino oil in my car.
Old 06-11-2007, 12:38 PM   #15
ttufrosty
Royal Purple 5w-30 7.50 a quart at Napa
Mobil 1 Extended Performance 5w-30 27.00 for a big 5 quart bottle at WalMart
So not quite 80.00 to put in the car
ttufrosty is offline   Reply With Quote
Old 06-11-2007, 04:02 PM   #16
Treyz
~ ambient one ~
Treyz's Avatar
Yaris I havent upgraded anything yet but as for the 240 .. Royal in the motor, diff, and tranny. Actually have seen proven dyno results for HP gain (2001 Camaro +8hp). Also does well for fuel economy. 240 gained mpg.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 06-11-2007, 04:37 PM   #17
JosephDoc
Drives: 07 Yaris 3D
On oils, I use Nenos. Sorry, I am JDM to the bone.
I think Nenos is better and RP, and I can save gas when using 0w20.
Eneos's web sit.
JosephDoc is offline   Reply With Quote
Old 06-11-2007, 05:03 PM   #18
Treyz
~ ambient one ~
Treyz's Avatar
I'm interested .. taking a look into this Eneos
AMBIENTLIFESTYLE
Micro Image
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
