Old 02-25-2009, 11:27 AM   #73
TheSilkySmooth
TheSilkySmooth's Avatar
If I was lucky enough to live in FLA, SoCAL or DownUnder, I'd be running Straight HD 30, absolutely NOT a winter oil. VI improvers are not lubricants and are the leading cause of varnish and sludge and shearing out of grade. Our engines do not take kindly to varnish and are not THAT easy on oil given they have: the dreaded flat tappet cam, hydraulic cam phasing, timing chain and guide and a hydraulic chain tensioner.
Old 02-25-2009, 11:32 AM   #74
TheSilkySmooth
My 145 dollar 3.5HP briggs lawn mover is still alive after 19 years having only summer use, 30wt hdeo oil fill with OC every OTHER year. Burns no oil, doesnt knock. It has NO oil pump, just splash lube. OK thats my 300th post. WEEEeeee!
Old 02-25-2009, 12:00 PM   #75
jkuchta
Drives: 2007 Yaris hatch (red)
I run the Motul 300V 5W-30, and love it. This oil is designed for Le Mans....3-4K miles at full speed with no oil changes...I think it's more than enough for the street, and great for track days.
jkuchta is offline   Reply With Quote
Old 02-25-2009, 06:24 PM   #76
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Originally Posted by TheSilkySmooth View Post
You may want to try the Motul BMW LL01, prob the best all round oil around. I'll attach the spec sheet. The 300 v while it may work on the street for a bit is a racing oil. Sometimes they lower the detergency to reduce preignition, you need that detergency on a street motor. Cheers!
In Australia, it doesn't seem like we have a particular oil by Motul listed as BMW LL01.. But I've come across this one which does have the BMW LL-01 approval, is this the Australian Market equivalent?
Motul 8100 X-Max
The specifications seem similar - 100% synthetic, ester based, 5w30..
Old 02-25-2009, 06:34 PM   #77
ChinoCharles
Drives: LB
ROFL
Old 02-25-2009, 07:22 PM   #78
spookz
JDM yO!
Anyone know how the 1NZ-FE would run with 5w40?
Would it be too thick for the little engine?
Old 02-26-2009, 01:42 AM   #79
phenoyz
phenoyz's Avatar
Drives: yaris
after u change oil, is there something you need to "reset"?
like a honda or bmw you need to reset something.
phenoyz is offline   Reply With Quote
Old 02-26-2009, 01:59 AM   #80
If the maintenance light turns on before you change your oil, then yeah, you can reset that light.
Old 02-27-2009, 10:30 PM   #81
spookz
JDM yO!
Does anyone run 5w40 oils in their 1.5L Yaris?
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
