Old 03-14-2009, 06:54 PM   #55
yarstar
Drives: 2008 Absolute Red HB
AEM CAI.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-16-2009, 12:34 AM   #56
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Can T-Sport chime in and confirm he still has no CELs after the swap?
Old 03-16-2009, 08:04 AM   #57
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
yes, I don't have any cel at this point since the swap, I'm thinking maybe the different intake tube/pipe? I'm using the OEM one.
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 03-16-2009, 08:49 AM   #58
yarstar
That could be it. I've got a CEL and I have a Cold Air Intake.
Old 03-16-2009, 11:07 AM   #59
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
does anyone that uses a CAI have the stock one to toss back on to try it out? T-Sport is the bottom of your stock intake gutted? or is it completely stock?
Old 03-16-2009, 12:14 PM   #60
Lafiro
Drives: 06 Yaris Sedan
Can anyone dyno their car to prove what this TB swap really does.
So far no asnwer to this question, and it just seems like everyone is jumping on something that just makes the engine rev qierdly and pull "harder" but ok.
Old 03-16-2009, 12:42 PM   #61
Nexus1155
Drives: Audi
well i mean its an easy concept, larger mm throttle body = more air. to get the most out of it you either need a tune or be FI.
Old 03-16-2009, 03:48 PM   #62
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
well i have put almost 100 miles on it since my last post, the light has been gone the whole time. maybe it had to relearn after the chip swap...idk, but its gone. if it does not come on during my drive to work today then the problem is solved.
mikenacarato is offline   Reply With Quote
Old 03-16-2009, 04:54 PM   #63
Lafiro
And how much faster is your car now honestly? I would really like to know.
I do know the larger TB makes a big difference on some cars, and this is why Im making it such a big deal to learn what a difference this makes to the Yaris.
Thanks.
Old 03-16-2009, 07:42 PM   #64
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
I'm running with Blitz SUS POWER Air Intake with the OEM intake tube
Old 03-17-2009, 04:28 PM   #65
Jerkratt
Jerkratt's Avatar
would the TRD CAI fit over the TB opening or would i have to "Lip" it?
"It hurts more when its wet"
Old 03-18-2009, 04:10 AM   #66
dallas
Drives: Yaris Hatch /Landrover D2
How much bigger is the new throttle body opening than the intake it bolts to, as the intake side may become the restrictor? From the picture it looks like it has a step so you can't really port match it to the new throttle body.
dallas is offline   Reply With Quote
Old 03-19-2009, 11:24 AM   #67
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
I'm very sure you can, the other memeber has an TRD intake and he has been running with the new tb.
the pic of the my OEM tube has already been ported .25" bigger
1nz = 2"
1zz = 2.25"
just a report back it's been 11 days since ,my chip swap, cold start idle is around 2000 RPM instead of 3000 before, drops down to around 1000 in a couple of mins, when the car is fully warmed up, it idles at 750 RPM, no CEL the whole time, very happy with the extra mid-nigh end gain, can definitely feel the difference by my butt dyno even off the line, much better mod than an intake or exhaust if you can find one cheap, perhaps I couldn't even feel a difference when I upgraded my intake nor exhaust alone by my but dyno expect the increase of engine noise, but this one, I surely CAN.
Old 03-19-2009, 12:28 PM   #68
YarisSedan
Drives: 08 Yaris Sedan
I am thinking the same thing.
Old 03-20-2009, 08:58 PM   #69
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
you need a flared silicone rubber adapter
Old 03-24-2009, 04:31 PM   #70
hatchbackkid82
Drives: .
Doing this today, wish me luck Hopefully i won't get any CEL.
Old 03-24-2009, 04:32 PM   #71
hatchbackkid82
Drives: .
I have the AFE intake. Mine just went right over the TB, of course it took a lil muscle but it's on there, snug fit didn't even have to tight the clamp too much.
Old 03-24-2009, 07:12 PM   #72
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I was not able to do this at all with the OEM hose + Simota SRI. Did you get the hose wet in order to make it more flexible?
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
