Old 03-17-2009, 12:23 AM   #19
severous01
as a toyota employee. and a maint mechanic...the 'kit' from the factory assumes you have the other parts necessary to install the clutch. the clutch includes the clutch and the pressure plate cuz those are the only parts covered under warranty unless the maint mech says the throw out bearing is bad.
so.....the kit will only include parts under warranty....and thats the clutch and pressure plate. the mechanic should have an installation tool in the parts bin to install this clutch so it also wont be included.
throw out bearing is a diff part because if the clutch is used right it will last 200k miles. that means no resting foot on clutch pedal. not holding clutch in at red lights or stop signs...and def not red-lining with the clutch held in. the TOB is a temp bearing and is only designed for light use with light RPM usage.
severous01 is offline
Old 03-17-2009, 12:31 AM   #20
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
mikenacarato is offline
Old 03-17-2009, 10:28 PM   #21
frownonfun
frownonfun's Avatar
wow i didn't know all of those things were bad... i guess i should stop then.
frownonfun is offline
Old 03-17-2009, 11:25 PM   #22
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
My throwout bearing is fucked then
PHXDEMON is offline
Old 03-17-2009, 11:26 PM   #23
PHXDEMON
PHXDEMON's Avatar
I knew about holding the clutch in but I very lightly rest my foot on the clutch sometimes in traffic
PHXDEMON is offline
Old 03-17-2009, 11:35 PM   #24
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
WOW I knew nothing!!!
R-CaT
Project Yar 2ZR
RagnaCaT is offline
Old 03-23-2009, 06:31 PM   #25
mikenacarato
SIPNDEW
Drives: 15 STI
bump
Old 03-23-2009, 09:31 PM   #26
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
every clutch job i got i bought the throw out bearing regardless
your spending money on the clutch why would you cheap out on that
im gearing up for a clutch swap on the MR2, after 78K miles the stock is finally giving out
centerforce + fidanza flywheel = awesome
i dont know how long my stock yaris clutch will last
im guessing a long time?
kustom play is offline
Old 03-24-2009, 12:04 AM   #27
mikenacarato
SIPNDEW
Drives: 15 STI
am i going to have to make a new thread?
Old 03-24-2009, 08:29 AM   #28
Jerkratt
Jerkratt's Avatar
sorry my hours got cut i dont have the money atm
"It hurts more when its wet"
Jerkratt is offline
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
exedy hyper clutch kit... ae92trueno7 Performance Modifications 14 03-15-2009 12:24 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck trini_per4mance Items for Sale by private party 0 12-20-2008 12:16 AM
TRD BODY KIT phenoyz Cosmetic Modifications (Exterior/Interior) 3 11-08-2008 12:15 PM
