Old 03-11-2009, 12:31 AM   #1
ae92trueno7
ae92trueno7's Avatar
Drives: 2007 Yaris Supercharged
exedy hyper clutch kit...
hey i guys... i just got my exedy hyper clutch kit.... just wondering if anyone has installed one b4?? and if there is any problems installing it????
ae92trueno7 is offline   Reply With Quote
Old 03-11-2009, 03:13 AM   #2
"hyper" - what is that? I have a stage I, very twitchy but I like it.
Old 03-11-2009, 11:21 AM   #3
ae92trueno7
i dont know.. maybe that just wat they call it... it comes with a pressure plate, clutch, and a lighten flywheel..... is ur clutch made by exedy too??
Old 03-11-2009, 11:35 AM   #4
yes. This is what I have (stage 1 in case the link isn't accurate):
http://www.exedyusa.com/race/Clutch_Specifications
I'll probably go with a Stage 2 with my motor swap.
Old 03-11-2009, 04:44 PM   #5
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
Eh, Hyper clutch is good for high torque and i dont suggest you to install on yaris. Go with Stage 1 like cali yaris (Garm) told ya.
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-12-2009, 02:47 AM   #6
ae92trueno7
its too late now haha.. its already bought!! thinking of putting it in this week or next week... why not the hyper kit?? theres going to be a big difference?? u think?
Old 03-12-2009, 02:51 AM   #7
From Exedy's site. 2x OEM? Probably gonna be pretty stiff!!
Part Number: TH06SD
All Hyper Clutches come with a steel flywheel and a 6-puck disc with cerametallic facing, and a spring center damper. The disc is generally smaller and thinner than the OEM disc making for lower inertia and therefore quicker, easier shifting. The higher clamp load and cerametallic friction facings give approximately twice the holding torque of the OEM clutch and generally higher than other single plate clutches.
Specs
Number of Discs Single
Spring Damper Discs Sprung Center Disc
Push / Pull PUSH TYPE
Disc Outer Diameter 200mm
Spline Teeth / Major Diameter 21T / 24.1mm
Old 03-12-2009, 02:54 AM   #8
ae92trueno7
stiff?? as on sghifting or the clucth pedal??
Old 03-12-2009, 03:10 AM   #9
ae92trueno7
cali_yaris...by the way u have the quote for me/?
Old 03-14-2009, 08:48 PM   #10
ae92trueno7
got the clutch put in.... it is very stiff and sensitive!!..... keep on stalling!! hahah
Old 03-14-2009, 09:02 PM   #11
yeah, I still stall with my stage 1 sometimes.
Old 03-15-2009, 01:03 AM   #12
ae92trueno7
now i dont smell any clutch burning when i floor it to 5-6000rpm!!
Old 03-15-2009, 01:08 AM   #13
White Yaris
Broke Tuner
Drives: White Yaris
nice! yeah im sure its stiff very stiff lol.
Old 03-15-2009, 01:58 AM   #14
ddongbap
You must have had a crappy stock clutch when you floor it in that range.
Old 03-15-2009, 12:24 PM   #15
ae92trueno7
i looked at the old clutch and it wasnt that bad!! it might be the supercharger... pressure plate was not clamping enough causing the clutch to slip...
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck trini_per4mance Items for Sale by private party 0 12-20-2008 12:16 AM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
