Old 10-01-2006, 06:21 PM   #1
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
Can I install these speakers to the front and rear of my liftback?
What would be needed to have the speaker exposed? Adapters? brackets? McGyver?
I can get both the 6.5 and 5.25 in this model, but by looking at the way the speakers mount (specially the rear) loks like it would be a PITA.
I know I would have to cut out the holes to acomodate these speakers, but is it possible?
Thanks in advance!
Here's the speaker:
W.A.S.P is offline   Reply With Quote
Old 10-01-2006, 06:33 PM   #2
johnnyfive
johnnyfive's Avatar
you would only need to cut anyhting if you want to use the grill that is with them, the speakers themselfs should just mount up like any other speaker would
johnnyfive is offline   Reply With Quote
Old 10-01-2006, 07:24 PM   #3
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
I have 6.5 Polk db650 all around and they work great
http://www.crutchfield.com/S-e4H0m3q...asp?I=107DB650
YamilR is offline   Reply With Quote
Old 10-01-2006, 08:59 PM   #4
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Yes, the idea is to use the gril that copmes with the speakers. Is that possible?
Old 10-01-2006, 09:06 PM   #5
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Great!!!!!
Did you install them yourself? Is there anything that I need to be prepared for upon installation of the speakers? Special mods besides the cutting of the plastics?
TIA.
Old 10-01-2006, 09:23 PM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
So u want to "SHOW" your speakers? like this??
PS. i know the back speaker isnt in the right place. Just givin an example.
Old 10-01-2006, 11:24 PM   #7
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Exactly like that! Do you think it's possible?
Old 10-02-2006, 01:24 AM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
Yes. Yes it is possible, but im not the one to show u a detailed tutorial about it. I have some idea on how to do it but not 100% sure.
I noticed that u drive a 2door liftback.........im just thinking how u gonna mount the back speakers into the panel. :S
Old 10-02-2006, 01:59 AM   #9
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
I'm not sure... I asked because for what I've been able to see the actual speaker does not align with the perforated plastic panel. I wonder if it can be moved.
Old 10-02-2006, 03:42 AM   #10
hasher22
Look mum no stars!!
hasher22's Avatar
yea i know the back speakers for the rear of the 2door liftback is fuked.....they didnt positioned it prop.
somehow u have to cut a hole within the panel, and screw the speakers in the panel, yet somehow make it stable to the metal door panel.
Well im no help........................PEOPLE HELP HIM OUT!!!
Old 10-02-2006, 04:08 AM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
I've no idea how to deal with the 3dr liftback speakers.
For the front, I don't suggest cutting the door panel plastic just to mount the grills. The grills will vibrate unless you make some fibreglass housing for it to mount behind the door panel after you have cut it.
For the front and back speakers, you will definitely need spacers.
My front speakers have a mounting depth of 2 5/8" and even with a 1/4" spacer, the speaker magnet hit the window when it went down. I had to improvise and create some tabs for the three holes to sit on so that the speaker could sit properly. Because of this, I have dead air sitting between the spacer and the metal on the door. If anyone has installed/used Focals, you will understand this dilemma.
Make sure that there is no air between your spacer and the metal door, and also no air between the speaker's mounting diameter and the spacer. You want all your components to sit flush with one another so the sound is reproduced properly.
There is a spacer template that I made for the front/back speakers for the hatchback. I suggest using 1/2" MDF to make your spacers in the event that your speaker has a large mounting depth and big magnets.
Edit: If you don't want to deal with spacers, you can destroy your stock speakers by gutting them and then mounting your new speakers on top of them. I am not sure if the stock brackets (what's left over after you destroy the speaker) will allow for large mounting depths AND big magnets.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 10-02-2006, 07:14 AM   #12
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
dont forget... showing off your audio equipment opens yourself up to a greater risk of theft. i always try to make my suff look as stock as possible.
i wonder who a thief is going to hit first: my car, or the one next to me with a 4' long "ALPINE" sticker on the back window.
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 10-02-2006, 07:55 AM   #13
YamilR
YamilR's Avatar
I had them mounted for me, I dont like the idea of cutting a hole on the door, and be sure you Dynamat the door panels
Old 10-02-2006, 10:14 AM   #14
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Do yourself a huge favor and toss out the grills that come with the speakers.
Old 10-02-2006, 11:33 AM   #15
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
unless that is you want to have a cut your door panels...
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 10-02-2006, 01:50 PM   #16
bigsky2
Cousin Vitz
bigsky2's Avatar
With the HATCHBACK, you don't have to cut anything.
Well, maybe.
Depending on how crazy your component or coaxials are for the front doors, which are 6.5", you may or may not have to cut the door panel.
Here's the situation...
When you remove the door panel and look in the inside of it, you will notice that there is a circular trim on the inside of where the "speaker grill holes" are located. I am guessing this is the speaker "grill" that is integrated right into the door panel. I didn't examine it long enough to see if it can be removed or modified.
I think the diameter of this trim is bigger than 6.5" so it won't touch the top/cone area of the speaker once you put the door panel back on.
But if you are using big ass components like the Focal K2 series, you will need at least 1/2" spacer to bring up the magnet to prevent it from hitting the glass. The stock bracket is pathetic for this application, so I seriously suggest using a spacer if you intend to install high quality component speakers.
You can probably get away with using the stock bracket to mount coaxials.
Old 10-02-2006, 01:51 PM   #17
bigsky2
Cousin Vitz
bigsky2's Avatar
Grills are only used for TOP MOUNT applications!
You don't need to use a grill if the speaker is mounted and hidden inside your door panel!
Old 10-02-2006, 03:08 PM   #18
vodkalush
I drive a yarrrris
vodkalush's Avatar
well you dont "need" to but some people like the look of the speaker grills that come with the speakers.. and in that case (atleast with the sedan) you'd have to cut the door panel speakers "grill" off to enable your use of the aftermarket ones ( i personally like the look of stock). To each his own.
and i hope all goes well with the install.
fyi, you'll notice the sound is better, but you may want to think of getting an amp installed if your looking for overal system improvement/volume.
will work for parts
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 03:40 PM
