Old 09-10-2006, 01:14 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
DIY 07 Sedan Rear Speaker install
Steps (images attached)
0 - Tools (see image)
1 - Stock Speakers/rear
2 - Remove headrest
3 - Open trunk and press up on 3rd brake light's side tabs
4 - Pull third brake light and unhook the cable
5 - Go back to trunk and press-up on the three plastic rivits holding down the felt/material (which the speaker gaurds are attached to)
6 - Make sure you got the right ones
7 - Unscrew the car seat restraint brackets (3 total)
8 - remove 4th plastic rivit (holding front of cover)*
9 - *Use what's provided. I used the rear cup holder to hold all removed screws/brackets/plastic rivits
File Type: jpg 8 - plastic rivets removed and 3rd brake light removed.JPG (53.9 KB, 2034 views)
Old 09-10-2006, 02:28 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Rear speaker cont.
10 - (forgot to take pic - but to take off the rear cover simply put you hands under it and start lifting and gently pulling forward; start from one side and work you way to the other side) picture shows what you should see
11 - The stock speaker; remove foam padding.
12 - Disconnect the speaker wire
13 - Unscrew speakers (4 screws each speaker)
14 - Since the stock speakers are to big you need to buy/make (since this is diy i made mine) Outline stock speakers onto MDR (not what i used... but its what you should use). I would recommend cutting out the center first, then drill the holes and then finally cut out the spacer/holder.
15 - My finished bracket
16 - Speaker attached to new bracket
17 - Place new speaker into the speaker spot, plug in new speaker (cut off old speaker then splice onto new speaker) then screw down the bracket. Put the foam back on.
18 - Place the "cover" back on. screw the carseat brackets back on. install all of the plastic rivits.
19 - Finally just double check that everything is put back together.*
Old 09-10-2006, 04:48 PM   #3
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Nice Tutorial!
Old 09-10-2006, 09:14 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
A few questions:
1) How long did it take you?
2) What did you you use for your spacer?
3) Are you using the new ones with stock H/U?
4) If only using with stock H/U how do you like the sound compared to stock?
Thanks....great tutorial BTW....Toyota had told me the seat had to come out! If it is this easy then I will do it myself.
Old 09-10-2006, 10:15 PM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
1 - Well its hard to say... I had to figure how to get everything out and then had to go out and get my spacer material... but if you have all the right tools, and material you could prob. swap these out in an hour to 2 hours (including cutting time of spacers).
2 - I went to lowes and got a sheet of oak paneling (the stuff you find with plywood)
3 - I am using the stock head unit.
4 - The new speakers removed the "bass blur" and I no longer have to turn the volume to 20+ to hear voices in songs. I'd say it was a huge increase to overall sound quality.
if you rate stock speakers at say a "4.5" then its now a "8.5". The one thing I'm thinking about adding now is a amp... only because I like to drive with the windows open when I'm on the thruway.
will work for parts
Old 09-11-2006, 09:57 AM   #6
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Just curious... why did you replace the stock rear speaker of your Yaris with these Pio? I hear these exact Pioneer you install and they sound ten time badder than stock? So why?
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-11-2006, 10:42 AM   #7
Katana
Katana's Avatar
Why is that?10 times worse than before???
Old 09-11-2006, 10:47 AM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
I think they sound alot better then stock, the my stock ones blurred all the voices/sounds together... for example, if I was listening to Stern all I would here when he talked was a real bassy mess... now I can hear him and anyone else talking. I like them alot better then stock.
will work for parts
Old 09-11-2006, 12:06 PM   #9
Katana
Katana's Avatar
But I don't get it.
The rear speakers they totally suck!How can aftermarket speakers be worse than the stock ones?
Old 09-11-2006, 12:17 PM   #10
Lafiro
Drives: 06 Yaris Sedan
My Set up
I only got a 1000W amp powering two 12"s.
And I use the stock radio/steapkers on normal settings; except treble at +5. Bingo, good sound/enough voice :)
Old 09-11-2006, 12:29 PM   #11
Lafiro
Originally Posted by Katana
But I don't get it.
Probably because you can't just "plug and play" everything you get into stock units.
If I upgrade, I WILL power them using an amp. For now = >
Can Someone PLEASE tell me whats a good speaker for that "mid bass" thats missed by sub's. Thanks.
Old 09-11-2006, 01:51 PM   #12
SimmZ
BINGO!!! Exactly what I'm thinking.
The stock speakers do a real great job, personnaly I think Pioneer speakers are real craps exept for the higher end model maybe. If you want real great speakers, take a look to Infinity, Focal, Hertz, Alpine, ect.
Old 09-12-2006, 02:50 AM   #13
johnnyfive
johnnyfive's Avatar
blah blah blah....
Old 09-12-2006, 08:39 PM   #14
fnkngrv
fnkngrv's Avatar
Originally Posted by johnnyfive
blah blah blah....
How about in another language?
On a serious note I have ordered my Eclipse for both the front and the back...I can't wait. I won't have them on an amp at first...that will be in a couple months, but from hearing the ones I am getting in both Circuit City and then in a buddies grand Prix they are a huge difference....you would hope so since the 6.5s are running around 120 and then 6x9s are running at 1 1/2.
Old 09-13-2006, 01:03 AM   #15
azyaris07
azyaris07's Avatar
Factory Speaker replacement
First off, thanks for the GREAT installation tips! I have 4 Polk speakers just waiting to get installed, 2x 6.5 and 2 x 6x9 db series, and a 10" MTX sub. I also have an Infinity amp that I am planning on hooking up, 6 channel 4 x 52 and 2 x 107 watt (bridged to a single channel). I just need to find a place to put it! The trunk is the only solution (it is BIG!) but I still want to be able to get to my spare.. The stock speakers aren't too bad, but I like to listen to my tunes rather loud, and the stock setup just doesn't cut it. It sounds ok at lower to moderate levels, but washes out ALL of the bass and mids at a decent volume. In my experience with car audio, replacing factory speakers ALWAYS sounds better. (provided you give them enough juice)
azyaris07 is offline   Reply With Quote
Old 09-13-2006, 02:59 AM   #16
paultyler_82
I'm partial to Infinity myself but for the price, Pioneers sound rather good, in my opinion, definately better than the stock units. Never heard of Focal or Hertz... I'm sure Blaupunkts and Polks would probably be a nice improvement without totally breaking the bank as well, I'm going to reserve my comments on Alpine.
Old 10-20-2006, 04:21 PM   #17
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
Great tutorial , thanks & congrats!
I h have one concern..do you feel confident with the wood spacers? since the speakers are actually drilled onto the wood, and the wood is fixed to the chasis...if you put some punch to the speakers...would it cause tension that makes the wood to whip or even break ( sorry for my english!! )
With this said, are there any aftermarke metal spacers that we may get...?
Yaris-TJ is offline   Reply With Quote
Old 10-20-2006, 04:25 PM   #18
vodkalush
I drive a yarrrris
vodkalush's Avatar
Honestly I'm not worried (I dont play songs with alot of bass though...). But instead of wood I would recommend using MDF, which is what you are suppose to use... the only reason why i didnt use MDF was that I drove my yaris to the store that I was getting the wood/supplies (new drill bit and saw blade) and the only size MDF they had was a 4ftx6ft.
There are aftermarket speaker brackets... I'll see if I can find it. But if you use MDF you wont have to worry about it breaking or the speaker coming "free".
will work for parts
Rear Speaker size on Sedan? fnkngrv In Car Entertainment + Electronics (audio / video / alarm) 3 07-03-2006 02:39 AM
