Old 04-17-2009, 08:05 PM   #73
Castaway
Drives: 2008 Yaris hb 2d
Sounds like it's installed upside down...
Castaway is offline   Reply With Quote
Old 04-17-2009, 10:18 PM   #74
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I dunno...words read fine....lol
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-18-2009, 12:12 AM   #75
IllusionX
Drives: 07 Yaris Sedan Aero
i'm pretty sure it's who does it first. lol
too bad i wasn't in the crowd who "ordered it first"
Old 04-18-2009, 12:48 AM   #76
MadMax
MadMax's Avatar
yeah I thought so too...I'm pretty sure it's aftermarket as the switch itself doesn't toggle, it has three buttons....also there is no IPC light just a very bright annoying (at night) green light on the stalk to let you know it's on and ready to use.
the damn thing isn't visible through the holes in the steering wheel either, and it's backwards from what I'm used to....
top button is for decrease/set
side button is for on/off
bottom button is accel/cancel...weird huh....
Actually, I thought I had factory cruise control but that sounds like what I have, which I now suspect is a Rostra Precision Controls Inc. aftermarket set-up...does it look like this?
Plus, if that is aftermarket, what does the factory set-up look like?
BTW, the Rostra has been discussed before...
Old 04-18-2009, 03:26 AM   #77
Shroomster
Shroomster's Avatar
^^^that is the stalk that's installed
and this BELOW, is what an O.E.M toyota cruise stalk looks like...
courtesy of a toyotanation.com DIY
Old 04-18-2009, 04:52 AM   #78
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
So does this need to be run through the clock spring
if so does that mean we have to replace it as well.
just a thougt ,and probably a bad one.
Old 04-18-2009, 08:01 AM   #79
lunjiaow
lunjiaow's Avatar
Drives: Yaris
you may need the wire to connect it to the clockspring.
top pictures are from the corolla... assuming it will be some what similar to the yaris.
i think the part number for that wire is 84633-42030
lunjiaow is offline   Reply With Quote
Old 04-18-2009, 08:08 AM   #80
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I think the pic of the one I Bought showed a wire with it. If not Ill just make one, no biggie.
The guy told me it shipped but no tracking #? is that because its USPS?
Old 04-18-2009, 08:20 AM   #81
AlexNet0
AlexNet0's Avatar
lol, okay. I usually deal with UPS and FedEx, I guess im spoiled that way.
Old 04-18-2009, 08:25 AM   #82
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Well i just pulled my yaris airbag/horn out... and turns out to be like the picture above.
Old 04-18-2009, 08:31 AM   #83
AlexNet0
AlexNet0's Avatar
The thought crossed my mind as well
Old 04-18-2009, 09:08 AM   #84
Klink10
Klink10's Avatar
how hard is it tho pull off the cover? i a bit scared of taking it off since i dont want my airbag to blow up in my face
Pulling the cover was a piece of cake. Changed out my steering wheel to a Scion and the install took me 20 minutes. To disable the airbag, I disconnected the battery the night prior. Check here on the forum, I can't for the life of me remember who did this first but they did a good write up on how to. It really pointed out battery disconnect and prying the wires for complete airbag removal.
Old 04-18-2009, 09:17 AM   #85
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Yeah. its just two T30 torx bits on each side of the steering wheel. then just pull the horn/airbag off, be careful not to deploy the airbag and dont disconnet the airbag when battery is still connected. Its recommended to disconnect the battery and wait 60seconds or so to discharge power. I just wanted to check whats behind the steering wheel so i didn't disconnect the battery. Took less then 5mins to take out.
Old 04-18-2009, 12:43 PM   #86
IllusionX
my dealer had remove the top cover of my dashboard, and they did remove the passenger air bag without disconnecting the battery.
Old 04-18-2009, 01:33 PM   #87
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Airbag pullers: its very easy. Make sure the battery is disconnected for a few minutes (I think the manual says 3-6, I waited 10), then use the CORRECT torx driver to remove the 2 side-bolts (you'll need one with a bit of reach), and it might take a decent tug to break the bolt initially, but then its easy). You should matchmark your wheel before you pull it. You shouldn't need a wheel pullet, just tug back-and-forth till it comes off. If you move your closckspring at all, read the directions on how to reset it. Its not hard, but needs to be done right or it will be an EXPENSIVE repair, and might set-off the airbag when you are turning. This is not a process to be afraid of, just take your time and know the steps. BTW - the "clockspring" is the name for the circular plastic unit behind the steerign wheel that allows all the wires to reach the steering wheel/cruise/airbag/horns and still spin the steering wheel round-and-round, where some very old vehicles ran the wires through a hollow center shaft.
Old 04-18-2009, 02:39 PM   #88
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
The problem I am having are the torx screws on the side ... they seem really hard to get off lol. But then again I was using a regular screw driver ... would a torque wrench do it? Or should I be using more force?
devinlamothe is offline   Reply With Quote
Old 04-18-2009, 03:07 PM   #89
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
I was just reading this DIY a little while ago. I'm a huge fan of picture step-by-steps lol.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 04-18-2009, 11:06 PM   #90
Shroomster
Shroomster's Avatar
no...the TORX refers to the head/socket....
courtesy of fakeplasticrock.com
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 02:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
