Retrofit Blitz Supercharger
Well... its installed and fantastic!
This is an xA/xB kit I got used with 3000 miles and it came with all of the original mounting hardware and components. My boyfriend Kevin deserves a lot of credit for this project. I assisted and helped where I could but this project was a little over what I felt comfortable with in my mechanical abilities. Really though it went very smoothly, its totally worth it. For starters anyone thinking about getting a scion kit, realize that there are several main modifications you will need to make: 1 - Throttle Body (xA = 3 bolt; Yaris = 4 bolt) We made an adapter plate to mate the supercharger intake piece to the Yaris TB. I already bypassed the coolant line several months ago, in this project I shortened the coolant line that ran to it. 2 - Intake (xA = different position for TB; Yaris = you need a custom intake of some kind) We flipped the stock air box upside down to reduce the chance of CELs, so far so good. I need K&N style filter but I was impatient and wanted it running asap ![]() 3 - Pulley/Belt (xA = 66.7 to 67 in belt; Yaris = 66in belt) I am using the gatorback 66.7in belt with an idler pulley from Advanced, I'll try to track down the exact part number later. The pulley I bought was like $18 and gives a better wrap to the supercharger and I don't have any clearance issues with it. However the biggest change from my setup with others here, is my AEM water methanol system. I tapped my washer fluid tank (and installed the float switch in the washer tank) for lack of space of either the 2 quart or 4 quart AEM tanks. There is an led mounted in the car to tell me when the AEM is spraying and when the system is low. The pump is mounted on my right strut tower and the controller box is behind the lower passenger glove box. Can't think of too much else at the moment, its been 3 days up til 2am working on this project. Soldering in everything and taking our time really paid off. It cranked right up and runs like a champ! halfway through: ![]() completed: ![]() ![]() ![]() Its pretty loud, I might get some videos/better pictures this evening ~Mo
congrats! i'm glad it all worked out :) can't wait to see your numbers (and i can't wait for you to take "fastest SC yaris" away from our lil buddy
NIIIIICE
You get +400 cool points for not buying the out-of-the-box solution.
OMG, that is awesome, definitely need some vids, mad props
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
Fantastic!
Another boosted member
Who said Yaris was slow?
It would be interesting to see the effect of the meth injection on that set up.
That should take care of the knocking problems that other blitz users have reported and should prevent the ECU to pull in too much timing. Heck you might even get away using regular fuel on your car. Congrats! Post some numbers soon! |
![]() well done that looks amazing so jealous |
#9 | |||
![]() Quote:
Thanks! There are still a few loose ends to tie up and finish, but I'm still in shock that it cranked right up :smile; ---- I finally feel clean enough (after two showers and a soak in the hot tub)to leave the house and go show it off to some other car friends!
i have pieces that'd build you an amazing CAI for your setup. PM me
fuel controller just took some thinking to get right, matching up the pins on the ecu between the two cars to figure out which wire goes where...
the xA has one ground, the Yaris has two or three grounds - other than that it was pretty easy to figure out
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
How do you like the drive by cable response instead of drive by wire?
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Morgan will you please say more about the water meth injection kit?
I understand how it cools the fuel air mixture, but not clear about the other advantages/disadvantages. Does injecting water into the system have any negative effects? Also I wondering about cost--I experienced some of the things Castrex described, and right now I'm buying octane booster to combat but getting satisfactory + stable results. However, I haven't given much thought to the long term effects. If you factor in the cost of the water meth kit and buying the methanol, is this method still better long-term? PS to all -- if by asking this I unwittingly brought up a controversial topic or asked a dumb Q, please dont argue in Morgan's thread, mmmmkkaayyyy?
KK, I'm watching closely that throttle body adapter plate thread. If they make a threaded hole that will fit a water injector, that may be the way for you and me to go. Until then, just continue using the turkey baster.
#15 | |
water/meth injection has been used for over 50 years, and does not harm your engine if done properly
Tamago, I consulted Google before asking, and still came away with questions. I was hoping someone like you would be willing to elaborate, or that she might like a chance to explain it herself. But for Morgan's sake I'll ask in a different thread. Thanks anyway.
Apexing Egg!!
wow, really cool...
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
well done!
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Belt Part #'s For Blitz Supercharger | whooppee777 | Forced Induction Forum | 33 | 08-31-2017 11:46 AM |
| anyone with Blitz supercharger? | yrsdrgn | Performance Modifications | 52 | 08-24-2010 07:57 AM |
| Blitz Supercharger vendors | sdyaris | Forced Induction Forum | 32 | 09-18-2009 12:28 AM |
| blitz supercharger!!! | djgab101 | Australia | 4 | 11-20-2008 05:06 AM |
