Old 02-23-2007, 03:54 AM   #1
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
anyone with Blitz supercharger?
Anyone install a Blitz supercharger on their Yaris yet? Just curious.
Old 02-23-2007, 05:06 AM   #2
Look for a member here called Teruyume, only one here with a Blitz SC, I believe...
Old 02-23-2007, 02:47 PM   #3
YarisGuy
Drives: 2006 Yaris
YarisGuy is offline   Reply With Quote
Old 02-23-2007, 05:31 PM   #4
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
nice but i'm talking about the one made specifically for the Vitz or Yaris
Old 02-23-2007, 06:03 PM   #5
Kitt
Kitt's Avatar
Originally Posted by YarisGuy View Post
Did it came with a different cylinder head cover or you had to cut it???
Old 02-23-2007, 09:28 PM   #6
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
That was cut.
eco is offline   Reply With Quote
Old 02-24-2007, 12:08 AM   #7
Lafiro
Drives: 06 Yaris Sedan
Is the Blitz adjustable? Like to make it give more boost then its default amount?
Old 02-24-2007, 12:19 AM   #8
Yeah it has a controller that allows no boost, or 2 or three levels of boost. Pretty fancy!
Old 02-24-2007, 12:26 AM   #9
Lafiro
Nice, but what Im now trying to say is that, if there is Off, Low, Med, High....
Is there Very High? Super High? Set your own boost High?
Maybe I'm just high right now? lol
No seriously I would want to have atleast the capability to have it make up to 200hp instead of what? 130?
Old 02-24-2007, 12:51 AM   #10
erm there's a physical limitation to how much boost a supercharger can make, you could increase that by overdriving the pulley, but then again you can probably only push it so much over spec before it loses efficiency/overheats and dies.
Old 02-24-2007, 12:25 PM   #11
Lafiro
Ok, that does make sense, but then I guess that would mean I myself would just want a S/C that can produce more boost for our engine.
Would that be to much to ask for since a 20-30% increase just doesn't cut it for a few $$$$....?
Old 02-24-2007, 10:11 PM   #12
It's totally possible, but remember that this blitz SC has been chosen/engineered to be a best fit for our engine. You could strap on a bigger one, but its specifications may not be suitable for the engine, and create trouble down the line, especially if the engine's internals are not strenghtened. By all means, be a pioneer and try
Old 02-24-2007, 10:20 PM   #13
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
The Blitz SC is exactly what it is marketed to be - a bolt-on supercharger. Which means that they've increased horsepower with an eye on engine longevity based on the components that are inside the engine, and so the boost is mild.
The Vios Turbo (turbocharged 1NZ) in Thailand makes only 150-ish and that is a factory job.
You do want to drive your car for more than a few hundred miles/kilometres before a hole is punched out one side of the engine block, don't you?
The problem with turbo setups is that its so easy to get greedy and wind up the boost for just the bit more power. But the rest of the components, are they up to it? And 200hp sounds like a ground up rebuild to me......
Oh, don't forget to leave a bit of money for brake upgrades. In fact, do the brakes first.
Old 02-24-2007, 11:25 PM   #14
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
the theoratical ideal compression ratio after boost is 12~14:1
the stock engine is about 10.5 to 11:1 depend on ca or us or jp model.
if u have a 6psi of boost ur engine will be around 16:1 compression ratio. that will be increase of thermal efficiency, required intercooler. and low compression ratio. usually a 8:1 compression piston, will be able to work with a 8~12 PSI of boost. but still wut getting into your engine is about 14:1 compression ratio.
to get over that u will need reenforced con-rod and crank and probably cylinder sleeves.
so in conclusion:
if u want HP not just get more boost, i need to get ur engine to ideal compression ratio (NOT more boost = more HP)
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 02-27-2007, 05:54 PM   #15
BulletProofAuto
Drives: 00 itr
USDM Blitz supercharge pricing has been released, just no availability yet.
http://www.bulletproofautomotive.com...il.php?ID=5270
BulletProofAuto is offline   Reply With Quote
Old 02-27-2007, 06:11 PM   #16
ChinoCharles
Drives: LB
Not a bad price John, not bad at all... especially after looking at the dyno sheet!
Old 02-27-2007, 08:09 PM   #17
spkrman
Drives: 1
not horribly priced, we'll see what else comes along.
I like the ability to go from 0 to level 1 to level 2 boost though... and perhaps have a pulley made for a little extra? :)
Old 02-27-2007, 09:51 PM   #18
BulletProofAuto
Drives: 00 itr
the benefit of the blitz supercharger is that it has already been on the market in japan for years, so you aren't taking a chance on a product that is new...just something to think about. cheaper is rarely going to be better when it comes to forced induction.
Gauge for Interest in JR Supercharger redglare45 Performance Modifications 36 09-17-2009 08:04 AM
Greddy xB Supercharger Papamoon Performance Modifications 2 02-09-2007 03:08 PM
Offical Blitz Supercharged JDM yaris Teruyume Photo-Video-Media Gallery 1 11-01-2006 01:32 PM
Supercharger? iampachino Performance Modifications 15 08-24-2006 04:51 AM
BLITZ COMPRESSOR yachi Photo-Video-Media Gallery 20 04-21-2006 08:14 PM
