Old 05-04-2009, 01:25 AM   #37
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
Also, changing the oil yourself gives you pride in your vehicle, and a sense of satisfaction in doing the job yourself. An oil change is the easiest maintenance item you can perform. I NEVER take my car somewhere to have the oil changed. I've had bad experiences with people putting too much oil in, not enough, spilling it all over the engine bay and then having my car smoke. Nope, just ME working on MY car thank you.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 05-04-2009, 01:35 AM   #38
Pitt Yaris
Drives: Flint Mica Sedan
Paying anyone to change your oil is a HUGE waste of money. An even bigger waste on the Yaris. I have done an oil change on 4 different family cars, and the Yaris is by far the easiest.
Old 05-04-2009, 01:36 AM   #39
Pitt Yaris
One reason I change my own oil is because it's easy and I'm cheap. The second and just as important reason is garages overfilling/underfilling/etc. as you said.
Old 05-04-2009, 02:46 AM   #40
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Originally Posted by Ramblin yari View Post
I paid $42 for an oil change, filter and tire rotation & balance. $60-$70 bucks would make me crawl under the car and do it myself.
20 buck oil changes for Dino and satisfactory filters already has put me under the car. The 60-70 buck changes are the average for all the dealors around here. There is Claremont Toyota who gives free changes for 3 years if you buy from them...but even if I did get my Yaris there, it's about 20-30 miles from me.
As someone else has already meantioned, I change my own oil so I can be touch with what's up with my car. There's something about looking, feeling, poking, pulling..etc on different things to know what's up with your car.
Old 05-04-2009, 07:04 AM   #41
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
Yeah, I change my own oil cheaper with synthetic than reg oil at Grease Monkey. If you shop you can get a good pure synth and filter for $25. Voorhees? We're almost neighbors.
Old 05-04-2009, 10:57 AM   #42
socko
Drives: 07' Liftback, man., Bayou Blue
And it's even easier if you remove the oil pan drain plug and put in a Fumoto oil drain valve (for about $20). Then, when you change oil, all you have to do to drain is to open the valve.
socko is offline   Reply With Quote
Old 05-04-2009, 12:20 PM   #43
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
I run my car on Amsoil and change it twice a year...
you have to change the oil every 3000 miles not because Toyota says so, but because thats what the normal drain interval is for most dino/mineral based oils.
Providing you keep the reciepts and follow the recommended drain intervals of the oil you are using and records of the mileage etc they CAN NOT deny you warranty...
The 0w-20 Amsoil I use has a 25,000 mile or 1 year change interval...
I change it arpox every 15,000 KM (10k miles ) I change it once in the fall and once in the spring.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 05-04-2009, 04:44 PM   #44
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Yep, Voorhees. :P I know nothing about cars, and i dont feel safe messing with my car trying to change the oil.
Twistoffate0817 is offline   Reply With Quote
Old 05-04-2009, 07:39 PM   #45
neo3.142
Drives: Yaris Base
which is a better oil to use syntec, mobil1, royal purple, red line?
neo3.142 is offline   Reply With Quote
Old 05-04-2009, 07:55 PM   #46
NJBob
NJBob's Avatar
I understand. I never used to do mine in my last car because it was hard to reach. LOL
I'd say they're all good as long as it's pure synthetic. Just go for what's on sale. You have plenty of time between changes to price shop between oil changes. Royal Purple is over priced in my book. There are lots of guys here who know better than me. Let's hide and watch.
Old 05-04-2009, 09:17 PM   #47
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Redline and Amsoil are about the top 2
oils as classified in 5 groups
group I oils are the cheap junk like castrol GTX, Q state etc
group II oils are better nown as syntheitc blends as they are a mix of group I and group III oils
Group III oils are what 99% of synthetic oils are made of... These oils are synthetic oils made from mineral/crude oil. Most use the hydro cracking method and use heavy amounts of pure synthtic base stocks as additives. Group III are far better then any group I or II oil. Castrol Syntec and Mobil 1 are examples of group III synthetics.
Group IV ~ V These are the best of the best and are not actually oil. these are lubricants but called oils to not confuse the mass public...These are not pumped out of the ground, instead and made by folks in white lab coats. Most contain extremely small amounts of mineral oil or no mineral oil at all. Group IV synthetics are POA based ( Polyalphaolefin )
group V are usually Ester based synthetics
Redline and Amsoil products are bother a group IV-V synthetic and contain no mineral oil. This eliminates any mineral by products that oxidize and form sludge and engine deposits.
I should point out BOTH buy their synthetic stock from Exxon/mobil1 so you know even though the formulas are different the base stocks use in Mobil1, Amsoil and Redline are all the same.
Royal purple Racing oils are group IV-V however the regular stuff is group III...
If you can't find or afford a group IV-V synthetic... be sure to use a quality group III like Mobil 1.
My #1 choise is Amsoil, Redline is also great but far fewer products available
don't forget... the engine is just 1/2 of it... be sure to change the transmission fluid as well. 75W-90 for the Manual trans and the universal ATF for the auto's.
Old 05-05-2009, 02:31 AM   #48
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Exclamation
$60-70 is the going rate for dealership oil changes?! Holy cow! That's double what the independent shops here charge. (Let alone doing it myself, which I've done for most of my life.) So much for getting all the service done at the dealer while the warranty lasts!
Old 05-05-2009, 08:15 AM   #49
NJBob
NJBob's Avatar
Salesmen say that's where all their money comes from.....service. They wanted to charge me $90 just to reset my Tire Pressure Sensors. A year later, I'm still seeing the yellow warning light. LOL
Old 05-05-2009, 09:38 AM   #50
1stToyota
1stToyota's Avatar
Just one thing to add: Amsoil's cheaper XL series isn't group IV, it's group III, as mentioned on their website.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-05-2009, 09:40 AM   #51
1stToyota
1stToyota's Avatar
Our sensors don't need to be reset. Must be a bad sensor or a fault in the system.
2008 Scion xD
Old 05-05-2009, 09:46 AM   #52
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
woah thats crazy.. over here people are hustling with the economy.. You can easily get an oil change for 17.99... and with synthetic u can hold out 7-15k fine with our yarii... but if you are paranoid, just stick with 5k... 3k is too close
Its a Chao!!!
Old 05-05-2009, 10:22 AM   #53
NJBob
NJBob's Avatar
Smile
I bought "S" wheels from "RocklandToyota" and put my steelies away for winter. The light came on when I changed.
Old 05-05-2009, 10:22 AM   #54
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
I agreed with TheRealEnth. I'll NEVER, EVER, EVER pay $60-$70 for an oil change. That is INSAINE.....
The best way to handle this is just go to WALMART, get a nice Full Syntetic and DO IT YOUR SELF
GioBatera
Giobatera is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 06:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
