![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
heavy braking
Under heavy brking at the end of the stop it sound like something hit smashing together like a control arm is pushing on somehing.
The suspension crossmember was replaced after hiting a pot hol. Should I get this checked out? |
kanye
if you are worried, just have it looked at. maybe something in the back or in a compartment made a noise, or just the noise of the brakes overheating was what you heard.
Ummmm, anytime you hear a sound "like something hit smashing together" and you don't know what it is, you need to get it checked out.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Loose articles in the trunk? Or maybe the spare mount needs to be tightened?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
It is coming from the front by the brakes
Never stuff around with brakes. Without them the only way you'll stop is.........
Take it to get checked.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
I think the heavy breaking is pushing the shocks doe\wn onto the bumb stop. I didn't cut them because they were TRD.
I have the same noise in the front right, not so much a smash, lol, but a clunk, but it is only when I come to a stop, not rolling braking. and only from the right side.
Its the shocks bottoming out hitting the bump stop. TRD didn't say to cut the bump stop but I think 1" would work better. Or if they ever come out with stiffer springs for these cars that would be the answer.
| "Tok" Sound when braking at low speeds (less than 10kmph) | buchieboy | General Yaris / Vitz Discussion | 30 | 02-16-2009 06:50 PM |
| Random thoughts about braking | LtNoogie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 12-28-2008 11:09 AM |
| ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck | trini_per4mance | Items for Sale by private party | 0 | 12-20-2008 12:16 AM |
| BBK/Brake Upgrade with EBD. | ddongbap | Performance Modifications | 4 | 08-24-2007 04:16 AM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
