Old 12-10-2008, 01:28 AM   #1
buchieboy
Drives: Toyota Yaris
"Tok" Sound when braking at low speeds (less than 10kmph)
Hi Guys, need your advice here.
My Yaris is experiencing some weird sounds during braking. A "TOK" sound comes up during stop and go driving (less than 8kmph), This does not happen at high speed braking.
Im driving an automatic by the way
Hope to hear your advice!
buchieboy is offline   Reply With Quote
Old 12-10-2008, 03:46 AM   #2
ddongbap
Like, TOK and thats it?
Or TOK TOK TOK TOK TOK TOK TOK TOK?
How old is the car? How many miles? How many times have you changed the brakes?
Old 12-10-2008, 03:57 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Sounds like a brake pad thats lost its retention spring and is rocking back and forth.
Old 12-10-2008, 04:03 AM   #4
ddongbap
Yaris pads have those?
Old 12-10-2008, 07:10 AM   #5
buchieboy
Just one Tok!
Car is 18 months old, 22,000 km. This has been present ever since.
Old 12-10-2008, 07:55 AM   #6
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
If it is a repeatable problem just bring it in to the dealer and get them to look at it. There's still warranty on the thing.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-10-2008, 11:49 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
Have you had your rear brakes cleaned and ajusted yet. Should be done every 10k miles. Or sooner. Otherwise that is your problem. Brake shoe lining has excessive travel to the drum. Clean all the dust and dirt out of the drum and off the backing plate. And properly lubricate the backing plate with brake grease and i garentee your problem should go away.
Notice i used the word garentee and should in the same sentence. =)
Old 12-10-2008, 11:56 AM   #8
mine does tok in the summer when i release my foot from the pedal.
Old 12-10-2008, 01:30 PM   #9
ddongbap
Mine likes to.. TOK to me at night.
Old 12-10-2008, 08:17 PM   #10
natethegreat38
Party like a Barack star
natethegreat38's Avatar
Drives: '08 LB MT
But if he said this has been happening since the beginning, it is not likely the problem. If it started suddenly you may be right but i don't think that is the case...
i don't feel like creating another signature, yet. Give it another week...
natethegreat38 is offline   Reply With Quote
Old 12-10-2008, 08:23 PM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
"TOK" hmmm could be abs kicking in..
Old 12-10-2008, 08:23 PM   #12
natethegreat38
Drives: '08 LB MT
tok all you want...
Old 12-10-2008, 10:34 PM   #13
ddongbap
Originally Posted by natethegreat38 View Post
tok all you want...
ZINGER!
Old 12-10-2008, 10:58 PM   #14
ddongbap
Dang........
Old 12-11-2008, 05:10 AM   #15
buchieboy
Thanks! i'll have the dealer do this next week!
hope the problem goes away!
Thanks!
Old 12-11-2008, 05:10 AM   #16
buchieboy
This also happens to me, have you tried to fix it?
Old 12-17-2008, 07:57 AM   #17
buchieboy
I recently discovered another "TOK" sound.
This happens when i step on the brake pedal and turn the steering wheel to the left it produces a single "tok sound" after that it doesnt produce the sound anymore no matter how many times i turn the steering to the left. It only reproduces the sound when i let go and press the brake pedal again and do the same procedure. The sound only comes up when in total stop.
I also notice that my steering wheel is a tad harder to turn to the left compared to the right.
What can be wrong with this?
Old 01-30-2009, 01:56 AM   #18
shastaylb
Drives: 07 Yaris Liftback
Rock tok?
Mine's been doing the same thing. I got behind the front wheel with a flashlight and discovered a rock in the hollow part of the brake rotor. I could see it through the vent holes in the backing plate. It only makes noise at low speed because centrifugal force holds it outward when the wheel is spinning faster.
I think I have to remove the brake caliper and pull the rotor off to get it out. I'm not sure how it got in there, but I have a gravel driveway and packed snow may have forced it in.
shastaylb is offline   Reply With Quote
