Old 05-18-2009, 07:42 PM   #199
lammy29
Drives: Yaris
what about these for the pockets?
http://cgi.ebay.co.uk/DIN-pocket-cub...3%3A1|294%3A50
or
http://cgi.ebay.co.uk/Snap-In-Din-po...3%3A1|294%3A50
lammy29 is offline
Old 05-18-2009, 07:47 PM   #200
IsLNdbOi
IsLNdbOi's Avatar
You should look for the authentic Toyota branded single din pocket w/ door. I've found some on eBay before. I think they came out of old Camrys.
IsLNdbOi is offline
Old 05-18-2009, 07:52 PM   #201
lammy29
Drives: Yaris
i tried searching, but don't know what to search for. the reason i trying find a different one is because its a usa seller and i prefer if possible a uk seller that way save time and custom payment
typed in toyota single din and found this what u reckon?
http://cgi.ebay.co.uk/Toyota-Verso-t...3%3A1|294%3A50
or even this one
http://cgi.ebay.com/ebaymotors/METRA...fAudioQ5fVideo
lammy29 is offline
Old 05-18-2009, 07:53 PM   #202
Originally Posted by lammy29 View Post
i waited 2yrs nearly..........
so i dont need to purchase the item your selling?
The part that this thread is about is the PZ489-B0330-00, which is one of the three Toyota parts that you need.
CTScott is offline
Old 05-18-2009, 07:56 PM   #203
The second one has this disclaimer:
"Please not if you are installing a stereo into a Japanese vehicle you will need the dearer din pocket kit as the standard width of a Japanese aperture is smaller than din size and the pocket has to fit from behind."
So, I think you need one which attaches to the brackets with screws, rather than a snap-in one.
CTScott is offline
Old 05-18-2009, 08:02 PM   #204
lammy29
Drives: Yaris
cool, just me making sure and wastin your time sorry!!
so would you say safest bet is the one you recommended first time?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=350203320551
lammy29 is offline
Old 05-18-2009, 08:04 PM   #205
IsLNdbOi
IsLNdbOi's Avatar
This is the Toyota one with the door:
http://cgi.ebay.co.uk/DIN-Pocket-Tra...3%3A1|294%3A50
found it after 5 seconds of searching.
IsLNdbOi is offline
Old 05-18-2009, 08:04 PM   #206
or even this one
This would work:
http://cgi.ebay.co.uk/Autoleads-FP-0...3%3A1|294%3A50
CTScott is offline
Old 05-18-2009, 08:06 PM   #207
I am not sure if that would fit. It depends on if the door width is less than 174mm.
CTScott is offline
Old 05-18-2009, 08:17 PM   #208
lammy29
Drives: Yaris
once again ima go into my local dealer and see how much i can get the three parts for and hopefully they will have it!! i let you know how it goes. maybe pm you becus i used like a whole page in this thread
lammy29 is offline
Old 05-19-2009, 06:47 AM   #209
lammy29
Drives: Yaris
"Well the prices are similar, in order to actually supply you with something I will adjust the postage a bit laugh.gif
Total price inc delivery 107.42"
managed to get the three parts for little bit cheaper after asking around was orginally £118. also ordered http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260363938539
hopefully will be here for friday!!!!! i let you know how it goes!!!
once again Thanks! cant wait!!!! i think i might need adapter so it can fit the alpine system right?
lammy29 is offline
Old 05-19-2009, 07:54 AM   #210
Yes, you need a wiring harness adapter:
http://cgi.ebay.co.uk/TOYOTA-YARIS-R...3286.m63.l1177
CTScott is offline
Old 05-19-2009, 09:47 AM   #211
lammy29
Drives: Yaris
cool i rang up halfords and prob pick up one later today or on friday
lammy29 is offline
Old 05-21-2009, 02:40 AM   #212
IsLNdbOi
IsLNdbOi's Avatar
Ground off the positioning pins on the HU mounting brackets. Was then able to position HU further back.
If possible, can you post pictures of your modified mounting brackets? Which of the positioning dimples did you grind off on each bracket?
So the new trim piece doesn't rest on the face frame of your head unit? If not, don't you see a gap / empty space around the face frame of your head unit (between the face frame and the trim piece)?
IsLNdbOi is offline
Old 05-21-2009, 07:21 AM   #213
I really don't feel like ripping everything apart again.
If possible, can you take and post up a picture of the side of your HU, as well as one of the mounting bracket. I will then use those to show you what I did.
The trim piece does rest on the HU. When the trim reaches the point where it snaps into place, the back side of the opening just meets up with the 'flange' on the face frame.
WeeYari is offline
Old 05-21-2009, 07:46 AM   #214
Here's a picture of the left bracket. You can see the six alignment bumps.
CTScott is offline
Old 05-21-2009, 09:29 AM   #215
Scott,
Can you give me two pictures of the bracket standing on its end as if it was in its mounted position. I would like one of both the inside, and outside of the bracket. It would be my intent to combine bracket photos, with one of the side of the HU so that I may draw arrows between the two to indicate re-alignment positioning.
Thanks.
WeeYari is offline
Old 05-21-2009, 09:49 AM   #216
Scott,
Thanks.
Stock radio with bracket mounted:
Both brackets viewed from front:
Left Bracket:
Right Bracket:
CTScott is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
