Old 05-21-2009, 07:21 AM   #11
Originally Posted by IsLNdbOi View Post
If possible, can you post pictures of your modified mounting brackets? Which of the positioning dimples did you grind off on each bracket?
So the new trim piece doesn't rest on the face frame of your head unit? If not, don't you see a gap / empty space around the face frame of your head unit (between the face frame and the trim piece)?
I really don't feel like ripping everything apart again.
If possible, can you take and post up a picture of the side of your HU, as well as one of the mounting bracket. I will then use those to show you what I did.
The trim piece does rest on the HU. When the trim reaches the point where it snaps into place, the back side of the opening just meets up with the 'flange' on the face frame.
WeeYari is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
