Old 05-22-2009, 10:10 PM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
this clearly states manual transmisison...
Old 05-22-2009, 11:02 PM   #20
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
yeah and for some odd reason a few posts up someone was questioning this topic for their auto tranny. sorry for the mis-confusion
Old 09-13-2009, 05:57 PM   #21
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
UHHHH..... digging old thread up...same go's here!
Going to change to "Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG)" after 7000 miles on the odometer. I have ground way too many gears from lack of pressing the clutch in all the way. I will feel better about getting the original gear lube out of the tranny.
I don't have a 24mm socket but the 15/16 I have fits well. The conversion is 24mm = 15.118/16 inch. Should I use my 15/16, or go buy a 24mm?
andaconda is offline   Reply With Quote
Old 09-13-2009, 06:21 PM   #22
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
I bet a good 24mm socket would be worth having. All my tools are with my Karts, leaving me with standard tools(and few of um), really like having metric around.
Doin the same with my car soon..., only 14k on it though. AX might be beating it up some though. Sooner the better I guess.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 09-13-2009, 06:41 PM   #23
advocate
Drives: car
Originally Posted by ttufrosty View Post
I was experiencing some grinding of gears especially 1st and 2nd. I decided to switch to synthetic.
Did you notice smoother shifting after the oil change?
edit: just noticed this was a necro'd thread. damn my luck.
Old 09-20-2009, 03:18 PM   #24
MUSKOKA800
MUSKOKA800's Avatar
I used a 15/16" (6 point impact type) socket today when changing over to synthetic. It fit just fine.
Old 09-21-2009, 06:56 PM   #25
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I made the switch to Redline MT90 a month ago-big difference-I have not missed a shift since it's that smooth. MPG's seem to stay in the mid-to high 40's now rather than the lower 40's before. Very much worth the $24 for two quarts of the stuff. I tried Mobil 1 gear lube at first-but learned that is a GL-5 and although that's ok according to Toyota it was not prefered as GL-4 was-so I through $18 away on some mobile 1 by mistake. Very happy with the Redline MT90 in the Yaris.
UTVitz is offline   Reply With Quote
Old 09-22-2009, 10:28 PM   #26
bronsin
bronsin's Avatar
What makes that oil purple? Purple dinosaurs? Food coloring?
Old 09-22-2009, 10:42 PM   #27
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
http://www.royalpurple.com/rp-company-history.html
Old 09-22-2009, 11:43 PM   #28
bronsin
bronsin's Avatar
I know....snails!
Old 09-23-2009, 12:01 AM   #29
mikenacarato
SIPNDEW
Drives: 15 STI
apparently you cant read.
Old 09-23-2009, 06:25 AM   #30
bronsin
bronsin's Avatar
They said its purple because its the color of royalty. But they didnt say how they made it that way.
Old 09-26-2009, 12:36 AM   #31
Henry G.
Drives: 2008 Yaris HB
Royal Purple is average stuff at best. Read the technical reviews.
Redline MT-90 is top notch stuff. This is a 15 minute job at worst if you have the right tools. You will notice smoother shifting and that grinding while going into reverse will all but disappear. Its a no brainer especially if you drive 25k miles a year like I do.
Henry G. is offline   Reply With Quote
Old 09-26-2009, 01:03 AM   #32
ddongbap
I'm rocking NEO oil.
Old 09-30-2009, 11:39 AM   #33
dorman68
Drives: Corolla
Great write up!!
2003 Echo - Auto Trans - 93,000 mi.
dorman68 is offline   Reply With Quote
Old 10-17-2009, 11:15 AM   #34
andaconda
andaconda's Avatar
Followup:
I did the change to Amsoil.
A couple of tips tho:
I jacked up the drivers side of the car so that I could get to both plugs easier - but while I was draining, I let the car down off the jack, and then jacked it back up again to finish the job.
I did use my 15/16 socket with no problem.
Have the pan ready - I mean really ready - when I pulled out the filler plug, it came gushing out and missed my pan by a mile -- like all over the frame members, all over the jack, all over the driveway -- So be ready for it!
Have a helper on top with the fill funnel while you hold the fill tube in the fill hole -- you don't want to waste a precious drop of this expensive gear lube.
Don't over tighten the plugs. They're not that tight - 29 foot pounds.
Now I can't honestly tell any difference, but the cold weather hasn't come yet and I don't have but a couple of miles on it.
But at least I know it is changed out and I feel better about it.
My kid has been ribbing me about this switch from dino to synthetic. He said "you'll do anything to squeek one more mile per gallon, won't you!"
Old 10-17-2009, 11:56 AM   #35
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
the pictures is down, can someone reupload it?
jamal1984 is offline   Reply With Quote
Old 10-30-2009, 09:28 PM   #36
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I put in AMSOIL MTG (http://www.amsoil.com/catalog.aspx?code=MTGQT-EA). I only have 9500 miles on the car, but it made a difference. There is less resistance in the gearbox at all speeds, especially low speeds. I've heard it only gets better with time.
I had access to a lift, but the job was VERY simple. I could have done it without a lift easily. Get yourself a funnel with a long tube, two quarts of fluid, and a 15/16th wrench.
It's worth doing. I'll probably change the fluid again in 20,000 miles. Why not?
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
