Old 06-25-2009, 11:49 PM   #1
djgab101
djgab101's Avatar
Drives: toyota yaris
Remote Starter.....
I was looking at remote starters..... just wondering if it is possible to get a remote starter for the yaris because to start the car the clutch needs to be down to start???
djgab101 is offline   Reply With Quote
Old 06-25-2009, 11:59 PM   #2
that is really easy to disable, just a jumper wire, any shop that installs remote starters will take care of that detail for you. You DO have to leave the car in neutral though.
I actually disable it on every car I buy.
Old 06-26-2009, 12:05 AM   #3
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
good questoin
and a good answer
i am looking into this too
Old 06-26-2009, 12:21 AM   #4
vten
I have a compustar remote start 5000as , but haven't have time to install them. it will work on manual or auto transmision with no problem.
they usually say it on the alarm specs, whether manual , diesel or auto only capable.
Old 06-26-2009, 06:51 AM   #5
djgab101
djgab101's Avatar
Originally Posted by BrazdonW View Post
good questoin
and a good answer
thanks for the advice.....
i really want an alarm cause my friends cars have all been broken into and
there sounds systems have been stolen!! i dont want that to happen to mine...
Old 06-26-2009, 07:00 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
i have a remote start. i recommend a neutral safety switch. you can DIY it for under $10.
Old 06-26-2009, 07:10 AM   #7
djgab101
djgab101's Avatar
wat remote starter do u have??
i was thinking of getting an AsianWolf remote starter.....
Old 06-26-2009, 09:34 AM   #8
I put an UltraStart remote starter on mine (mine's an AT though). It has the best range of any that I've installed. It can easily start my car from inside a store or restaurant.
They make a version for MTs that requires you to do a series of steps before shutting off the car.
http://www.ultrastarters.com/products/1256M.html
On MT's I think that the neutral safety switch method is better - you don't have to remember to do a bunch of steps to arm remote start mode, and even with the step mode, you could still skip putting it in neutral.
For the neutral safety switch you can use any remote starter and tie the neutral safety switch to the hood pin input (which disables the remote start mode if the hood is open). The hood switches ground when the hood is open as do the DIY neutral safety switches that I've seen (spring method and magnet/reed switch method).
Old 06-26-2009, 10:36 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
i used a magnet fastened to the shift linkage that was pointed at a reed switch fastened to the shift cage itself. put the magnet on the fore-aft shift rod and mount the reed switch directly above it on the plastic cage. worked great
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
warranty issues & remote start homerj In Car Entertainment + Electronics (audio / video / alarm) 14 11-27-2008 12:19 PM
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 10:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
