![]() ![]() ![]() Drives: '09 Yaris LB Join Date: Dec 2008
No RPM signal? Any ideas?
I installed a tach a few months ago with the provided wire clips. When I lost the rpm signal I figured it was because of a bad connection. However now I've made a new connection and the tach is not reading any rpm. All fuses are good and the tach is powering on. Is it possible or likely that it's a connection inside the guage itself? It's one of those 30 dollar sunpro things after all. Anyone in the NYC area have a scangauge?
If this damn car came with a tachometer in the first place, all this hassle could be avoided. I appreciate any thoughts... |
#2 | |
Start another Oil Thread!
sounds like a bad tach.
you nailed it sir.
I love momentum.
I'd agree with Tamago, I think the tach may have crapped out. I have the same tach and it's already starting to deteriorate (moisture is creeping in behind the face).
Make sure to check your power/ground connection too. |
#4 | |
Problem solved...for now. I walked around the corner and bought another tach. Same brand different size. In six months when this breaks I will buy something decent. I just HAVE to have a tach. On this car with such a silent stock engine and exhaust its so hard to tell what the engine is doing without some visual indication. Did I mention I think it's lame that toyota didn't spec one?
Thanks a lot guys. |
#6 | |
Anyway, this is why I recently ordered a SpeedHut "revolution" tach for my new (manual tranny) Yaris.
| NAV SYSTEM ANTENA SIGNAL BLOCKED BY TINT ON WINDSHIELD | Giobatera | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 07-08-2009 11:55 AM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 01:41 AM |
| Optimal RPM for shifting Gears ? | JapRulezz | Performance Modifications | 8 | 03-07-2009 05:16 AM |
| RPM Gauge Install | rwseattle | DIY / Maintenance / Service | 1 | 04-15-2007 01:23 PM |
| Turn signal audible alert | paultyler_82 | Performance Modifications | 7 | 10-01-2006 11:21 AM |
