![]() ![]() Drives: yaris sedan Join Date: Oct 2008
Flywheel
hi
i have a yaris sedan with pullies , k&n , sway bar , and header .. what are the benefits with the flywheel ?? it produces vibrations ?? Thanks |
I read somewhere that it rattles?
hi peterpoop
excuse my english but i canīt understand you .. |
I have the Fidanza flywheel. No rattling at all. (where'd you hear that?) The lighter weight frees up rotational inertia to increase responsiveness. It's just like a giant pulley in that respect.
A lot of work just for that though; unless you are doing more like a clutch or LSD at the same time.
thanks cali yaris !!
#6 | |
Oh well!Definately one day if my clutch ever goes out, I'm forking out the cash for a LSD and lightened flywheel!
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
my fidanza (same as Garms) does not "rattle" (wtf are you reading peterpooop?). and i had to re-learn heel-toe as the revs drop off much faster than stock.
IMO not an investment i'd make again if i was looking for power. it's simply NOT WORTH THE $$$. however, if you're making more power and are installing a better clutch (please no Spec clutches http://www.yarisworld.com/forums/sho...ht=spec+clutch you might as well pick up the Fidanza. even bolted to the Spec stage 3 which is heavier than stock, you drop 5lbs off your rotating mass)
i learned about reducing the weight from stock flywheel.. anyone ??
what did you learn about it?
sorry tamago, i hear about this..
here in my country the people they do with mustangs , chevrolet a more.. reducing the weight from the back side of the flywheel .. opose to the disc surface |
if you can find a shop who can lighten your stock flywheel for you safely and inexpensively i say go that route. :)
#14 |
Mine doesn't vibrate, it shouldn't. Increase power? Not horsepower directly, but helps with increased responsiveness, just like the pulleys do. Your car will feel like it "wants to go", for lack of a better description. The tech heads can describe it a different way, I'm sure.
#15 |
![]() ![]() Drives: Poor with a nice bicycle. Join Date: May 2009
#16 |
#17 |
Who said Yaris was slow?
Remember that is not just a matter of reducing weight... where do you reduce it is very important...
When talking about inertia and rotational mass... the weight on the outer side of the wheel is the most important. I've seen the OE flywheel of these cars and there is some material that could be remove... but really not that much and almost non near the edge... You have to be SURE the machine shop knows what they are doing... if they go crazy on the wheel it could break at high speed... not nice! (google broken flywheels) Also make sure they balance the wheel to at least the original values... Too much risk IMO If you really want this, go buy a Fidanza. |
| flywheel question | White Yaris | DIY / Maintenance / Service | 4 | 03-16-2009 09:34 PM |
| lightweight flywheel from fidanza | dngz | Performance Modifications | 34 | 02-03-2009 11:02 PM |
| Flywheel HP to wheel HP | andries | General Yaris / Vitz Discussion | 19 | 11-26-2008 07:03 PM |
| flywheel weight | yarisdarkness | Performance Modifications | 19 | 10-30-2008 11:22 PM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
