Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Sponsors Classifieds Area > Micro Image
Old 09-05-2009, 04:33 PM   #217
Brian
Brian's Avatar
My install begins now. Will keep you guys updated.
Old 09-05-2009, 04:40 PM   #218
LEGATO``
LEGATO``'s Avatar
YES!
Project LEGATO
Old 09-05-2009, 05:22 PM   #219
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
MY LIGHTS are sitting in Customs' , expect delivery Monday
Old 09-05-2009, 06:03 PM   #220
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Ah. lucky. Take plenty of pics of the install and the wiring please. thanks
Old 09-05-2009, 06:46 PM   #221
Brian
Brian's Avatar
Front bumper, eyelids, and headlight have been removed. Oven preheating. Taking lots of pics.
Old 09-05-2009, 06:47 PM   #222
PETERPOOP
PETERPOOP's Avatar
beautiful. thanks. good luck with the wiring. Are you going to try and get the halo rings to just turn on by themselves too? Camell was unsuccessfull at doing so.
Old 09-05-2009, 08:01 PM   #223
Brian
Brian's Avatar
Yes, I will try to wire the halos. Headlights done baking and lens removed
Old 09-05-2009, 09:14 PM   #224
Brian
Brian's Avatar
Just finished painting the housings satin black. Test fit of projectors is a perfect fit. No cutting or trimming required.
Old 09-05-2009, 09:30 PM   #225
LEGATO``
LEGATO``'s Avatar
well
since your the first one to report brian, are you gonna do the diy for this?
Project LEGATO
Old 09-05-2009, 09:36 PM   #226
PETERPOOP
PETERPOOP's Avatar
brian, camell needed to cut out a space near the turn signal to be able to adjust the cut off. He used a dremel for that. Is this required for us to do the same?
Old 09-05-2009, 09:46 PM   #227
Brian
Brian's Avatar
Originally Posted by LEGATO`` View Post
well
I will do the DIY when I finish
After test fitting, I don't see a need to do any cutting. I will know more once I reassemble eveything.
Old 09-05-2009, 10:59 PM   #228
PETERPOOP
PETERPOOP's Avatar
press on!
Old 09-05-2009, 11:08 PM   #229
Brian
Brian's Avatar
I now see why Camell had to do some cutting. If you want to lower the cut-off the projector
will hit the housing. I measure my cut-off height at about 35 1/2" but my car is also on jack
stands so I will leave it as is and cut later if need be. Everything wire up except halos. Working
on that next. Cut-off is very nice.
Old 09-05-2009, 11:14 PM   #230
PETERPOOP
PETERPOOP's Avatar
beautiful
Old 09-05-2009, 11:24 PM   #231
Brian
Brian's Avatar
Great news. Halos work perfectly. Wired to turn on when parking light come on. Now back in the
oven to re-seal the headlights.
Old 09-05-2009, 11:27 PM   #232
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
yessssssss
Originally Posted by sw07gt
Old 09-05-2009, 11:58 PM   #233
PETERPOOP
PETERPOOP's Avatar
great job. can you be sure to mention how to do this in your write up? Well atleast before I wire mine up when i begin the install tomorrow.
Old 09-06-2009, 12:04 AM   #234
JumpmanYaris
USAF_SrA_E-4
Yeah because I dont know much about it my self
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
