#217 |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
My install begins now. Will keep you guys updated.
http://www.cardomain.com/ride/3875996 |
#218 |
![]() ![]() ![]() Drives: 2007 Yaris S Join Date: Jan 2009
Project LEGATO
#219 |
MY LIGHTS are sitting in Customs'
, expect delivery Monday
#220 |
#221 |
Front bumper, eyelids, and headlight have been removed. Oven preheating. Taking lots of pics.
#222 |
beautiful. thanks. good luck with the wiring. Are you going to try and get the halo rings to just turn on by themselves too? Camell was unsuccessfull at doing so.
#223 |
Yes, I will try to wire the halos. Headlights done baking and lens removed
#224 |
Just finished painting the housings satin black. Test fit of projectors is a perfect fit. No cutting or trimming required.
#225 |
well
since your the first one to report brian, are you gonna do the diy for this?
Project LEGATO
#226 |
brian, camell needed to cut out a space near the turn signal to be able to adjust the cut off. He used a dremel for that. Is this required for us to do the same?
#227 | |
After test fitting, I don't see a need to do any cutting. I will know more once I reassemble eveything.
#228 |
press on!
#229 |
I now see why Camell had to do some cutting. If you want to lower the cut-off the projector
will hit the housing. I measure my cut-off height at about 35 1/2" but my car is also on jack stands so I will leave it as is and cut later if need be. Everything wire up except halos. Working on that next. Cut-off is very nice.
#230 |
beautiful
#231 |
Great news. Halos work perfectly. Wired to turn on when parking light come on. Now back in the
oven to re-seal the headlights.
#232 | |
USAF_SrA_E-4
#233 |
great job. can you be sure to mention how to do this in your write up? Well atleast before I wire mine up when i begin the install tomorrow.
#234 | |
USAF_SrA_E-4
Yeah because I dont know much about it my self
| Why people choose a 5dr Liftback instead of a Sedan?? | SimmZ | General Yaris / Vitz Discussion | 53 | 05-29-2007 10:28 PM |
