#19 |
this clearly states manual transmisison...
#20 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
#21 |
Going to change to "Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG)" after 7000 miles on the odometer. I have ground way too many gears from lack of pressing the clutch in all the way. I will feel better about getting the original gear lube out of the tranny.
I don't have a 24mm socket but the 15/16 I have fits well. The conversion is 24mm = 15.118/16 inch. Should I use my 15/16, or go buy a 24mm? |
#22 |
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
I bet a good 24mm socket would be worth having. All my tools are with my Karts, leaving me with standard tools(and few of um), really like having metric around.
Doin the same with my car soon..., only 14k on it though. AX might be beating it up some though. Sooner the better I guess.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com |
#23 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
#24 | |
#25 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I made the switch to Redline MT90 a month ago-big difference-I have not missed a shift since it's that smooth. MPG's seem to stay in the mid-to high 40's now rather than the lower 40's before. Very much worth the $24 for two quarts of the stuff. I tried Mobil 1 gear lube at first-but learned that is a GL-5 and although that's ok according to Toyota it was not prefered as GL-4 was-so I through $18 away on some mobile 1 by mistake. Very happy with the Redline MT90 in the Yaris.
#26 |
What makes that oil purple? Purple dinosaurs? Food coloring?
#27 |
SIPNDEW
#28 |
I know....snails!
#29 |
SIPNDEW
apparently you cant read.
#30 |
They said its purple because its the color of royalty. But they didnt say how they made it that way.
#31 |
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
Royal Purple is average stuff at best. Read the technical reviews.
Redline MT-90 is top notch stuff. This is a 15 minute job at worst if you have the right tools. You will notice smoother shifting and that grinding while going into reverse will all but disappear. Its a no brainer especially if you drive 25k miles a year like I do. |
#32 |
I'm rocking NEO oil.
#33 |
![]() Drives: Corolla Join Date: Sep 2009
Great write up!!
2003 Echo - Auto Trans - 93,000 mi. |
#34 | |
I did the change to Amsoil. A couple of tips tho: I jacked up the drivers side of the car so that I could get to both plugs easier - but while I was draining, I let the car down off the jack, and then jacked it back up again to finish the job. I did use my 15/16 socket with no problem. Have the pan ready - I mean really ready - when I pulled out the filler plug, it came gushing out and missed my pan by a mile -- like all over the frame members, all over the jack, all over the driveway -- So be ready for it! Have a helper on top with the fill funnel while you hold the fill tube in the fill hole -- you don't want to waste a precious drop of this expensive gear lube. Don't over tighten the plugs. They're not that tight - 29 foot pounds. Now I can't honestly tell any difference, but the cold weather hasn't come yet and I don't have but a couple of miles on it. But at least I know it is changed out and I feel better about it. My kid has been ribbing me about this switch from dino to synthetic. He said "you'll do anything to squeek one more mile per gallon, won't you!" Last edited by andaconda; 10-17-2009 at 02:19 PM. |
#35 |
The Beautification of Car
the pictures is down, can someone reupload it?
#36 |
I love momentum.
I put in AMSOIL MTG (http://www.amsoil.com/catalog.aspx?code=MTGQT-EA). I only have 9500 miles on the car, but it made a difference. There is less resistance in the gearbox at all speeds, especially low speeds. I've heard it only gets better with time.
I had access to a lift, but the job was VERY simple. I could have done it without a lift easily. Get yourself a funnel with a long tube, two quarts of fluid, and a 15/16th wrench. It's worth doing. I'll probably change the fluid again in 20,000 miles. Why not? |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Yaris Auto need help with tranny oil change | chrisada_to2a | General Yaris / Vitz Discussion | 2 | 05-17-2007 02:51 PM |
| DIY Oil Change | Bassmonkey | DIY / Maintenance / Service | 42 | 02-19-2007 09:37 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
