Old 09-18-2009, 09:20 PM   #1
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
Help with Fog Lights!!!!
I posted in the DIY forum but don't think it gets much attention so I'm gonna post here.
Didn't get instructions to install this... I attempted today and FAILED.
Click this thread....
http://www.yarisworld.com/forums/showthread.php?t=22431
for the situation. It's mostly just wiring I'm confused with..
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-18-2009, 09:36 PM   #2
kuyachris84
This is what I've done so far.
From Here I don't know what the rest of the wires do. If you look at the harness thingy I'm holding up. It's different colors. Mostly red, white, black. The tutorials on this site have green / blue wires so this is what confuses me.
There's also a red wire that i don't see in other tutorials.. it looks like it goes to the positive battery ... but I'm assuming we don't need it if I can get it installed the methods you guys use.
Can someone help me or explain to me what I do with these wires?!?
Old 09-18-2009, 10:41 PM   #3
kuyachris84
anyone?
Old 09-18-2009, 11:00 PM   #4
Lafiro
Drives: 06 Yaris Sedan
What kit did you get? I will TRY and get my pictures tomorrow from my camera or cell phone, dont have anything today since I just installed windows 7. But that second relay should not be in the mix.
Old 09-18-2009, 11:29 PM   #5
kuyachris84
the one garm sent... I don't know the name. cuz I'm at work now.. ill check wen I get home
Old 09-19-2009, 12:02 AM   #6
Nachtmensch
Drives: 02 Toyota MRS
http://www.yarisworld.com/forums/sho...og+lamp+wiring
btw, this is Kevin
Nachtmensch is offline   Reply With Quote
Old 09-19-2009, 12:15 AM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
if you emailed me i could have sent you the instructions .
the red wire with white plug plugs into the light harness
and then into the factory wiring inside the fuse box
under the bonnet .
Old 09-19-2009, 12:30 AM   #8
kuyachris84
Originally Posted by Nachtmensch View Post
I already checked that thread .. that's wut I based my install on... but my wiring looks / seems different
Old 09-19-2009, 12:41 AM   #9
kuyachris84
under the bonnet .
can u take a picture of what u mean?
if its not too much too ask. .. pls ^^
Old 09-19-2009, 01:17 AM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Take the Red wires with the white plug (as photo'd above )
jion it to the red wire comeing from the fog lights , then plug those 2 pinned wires
into the under bonnet fuse box . as per instructions below.
Here is the Microimage instructions
Old 09-19-2009, 10:11 AM   #11
kuyachris84
lights won't turn on
Okay, I finished the install and I think I have everything installed correctly... but the fog lights will not turn on. Tell me if u see anything wrong.
Connected red wires from fogs to the two red wires that goes into pin1 and pin2 slots in the bonnet.
Here's the two pins plugged into the fuse box.
Here is the red wire from the switch going into the yellow wire (pin3) in the D4 connector under the steering wheel.
Here is the yellow wire from the switch going into an 'orange wire' from the dimmer switch. The diagram of the dimmer plug looks different than from the instructions. I didn't know what color to tap into ... I think someone said orange on the forum before. Let me know if that's the right wire.
Here my Indicator on my dash says my fog lights are on when i press the switch but the fog lights don't turn on. =(
Help, please!
Old 09-19-2009, 02:40 PM   #12
Lafiro
I have the same problem. Remove the yellow wire and let it hang not touching anything.
Now turn on your fog lights, and they should work! Also make sure the ground is connected in the engine bay for the fog lights as well, don't forget that.
I also have Garms kit, it also came completely different then what the diagram asked for, with extra parts and cables. But at the end I got it working.
I am only stuck now wondering why it is that if I connect the yellow wire to the harness behind the light dimmer, that is doesnt allow anything to work.
Let me know what happens when you un-splice that wire to test what I said.
Old 09-19-2009, 02:55 PM   #13
kuyachris84
did u connect the red wires coming from the fog light... using both? or just one red wire?
just curious....
I'll try what u said.
Old 09-19-2009, 04:00 PM   #14
kuyachris84
I unspliced the yellow and it still won't turn on.
Can you take pictures of your install? How does mine compare to yours?
I wanna see how you setup he wires in the engine bay. I reconnected the ground in the engine to the negative battery. Did you end up using the white and black wire? Should i splice the black wire into the other ground wire?
Old 09-19-2009, 04:15 PM   #15
kuyachris84
I wanna know what you did here... i have the black and white wires (which came off the removed relay)... taped off and the two red wires connected to the two wires that go into pin1 and pin2.
Am I suppose to ground that second black wire?
I already have that other black wire connected to ground via battery.
Did you use only one red wire?
Old 09-19-2009, 04:31 PM   #16
I think my post (telling you I would email you the latest instructions) was deleted?
Old 09-19-2009, 05:03 PM   #17
kuyachris84
the part that confuses me in the manual is that it says connect the positive wire to the white connector.
there are 2 red wires. One with a loop and one red wire that was from the removed relay. Which one is the positive wire coming from the foglights to connect to that white connector in the instructions?
Old 09-19-2009, 05:12 PM   #18
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Okay the relay with the 4 wires attached you through away right .
the red wire from fogs goes to pin 1& 2
the white and black wire from fogs is EARTH . HAVE YOU EARTHED YOUR LIGHTS .
to me it looks like you wired in the large 4 pin relay disconnect it and throw it away , just like the instructions i sent you send to .
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
