#73 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
Looks like slimmer from ghost busters just hit your fog lights. xD
But yeah.. I do agree the fog lights from garm has a huge freaken gap. Enough so that water when its raining or snowing will get in. I just wrapped the fogs electrical wire in electrical tape up to the plugs. If it gets bad... I'll try to close the gaps with silicone.
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
#74 |
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
Today I went out and tried to start one of my Yarises. It had been 6 to 7 days since I last started each Yaris. The first Yaris I tried would not turn over. The second Yaris was completely dead. So I had to call AAA for a jump. While I have zero proof that the fog lamp kits caused the problem, for safety sake, I unplugged different parts of the fog lamps.
#75 | |
#76 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I had the glove box light in my truck kill the battery in less than 3 days when I parked it with the box open one time. I'm pretty sure the that battery has significant more capacity than a Yaris battery. Lights are evil.
#77 |
ellenbetty
There are other things that draw power from the battery all the time. A clock being the first thing that comes to mind. Plus a vehicle electrical system wastes some power even with every thing turned off. Electricity is always trying to find a way to complete a circuit. Some electrons will flow even when every switch is turned off. Plus with modern relays checking for things like door locked or door unlocked or built in timer expired to turn off over head light, modern vehicles consume more battery power than older vehicles all the time.
What gets me is that one of the switches to the fog lamps was unplug. Still the battery was dead in 7 days. I wonder if I should go out and start both of those Yarises every few days, and let the Yarises run for 1/2 hour, to make sure the batteries are charged. |
#78 | |
#79 |
If you don't drive the cars regularly you could always just get a trickle charger. A 1/2 hour at idle isn't going to do much for you.
#80 |
The battery shouldn't run down in 7 days. If it is, either the battery has an issue (in your case x2) or something is drawing a significant amount of current when the car is off.
#81 |
ellenbetty
I have not checked the main fuse on the battery terminal connector. In the modular home park where I live, each lot has just one parking space per home. My Mom uses the parking space besides our modular home. Her Subrau has the same problem. The alarm system kills my Mom's battery in less than a week.
#82 |
ellenbetty
I park in a over flow parking lot. I do not have access to a place to plug a trickle charger. According to my research 25 minutes at idle will charge a dead battery.
#83 |
ellenbetty
#84 | |
ellenbetty
I have already used the jump starter once. Last edited by ellenbetty; 09-26-2009 at 11:43 PM. |
#85 |
I have something like that for car shows. Someone always runs their battery down bumping tunes, it's nice to be the guy with the jump start box.
#86 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
The other solution is deep cycle marine-type batteries, they'll take licking and keep ticking. Those batteries aren't just meant for the heavy duty stereo guys.
#87 |
ellenbetty
I not much for throwing away a new battery. What the Yaris really needs is a larger alternator. The owners manual says that the Yaris alternator is too small to generate enough power to heat the rear window defroster. So the rear window defroster draws additional power from the battery. The owner manual warns owners not run the rear window defroster more than 20 minutes. So the Yaris does not recharge the battery very fast. So a number of short trips could leave the battery without enough power to start the Yaris.
#88 | |
![]() I have been running a sub and an amp since the first day I had my car, and my car has never failed to start in 3 years and 74,000 miles. Original starter, alternator, and battery. |
#89 | |
USAF_SrA_E-4
#90 |
ellenbetty
74,000 total miles divided by 3 yeaers = 24,666.66 miles per year. 24,666.66 miles divided by 365 days per year = 67.5 miles per day. 67.5 divided by 2 trips per day = 33.75 miles per trip every day. Your equation may very. My Yarises are 1.6 years old. The Yaris I bought used has 14,000 miles. The Yaris I bought new has 12,000 miles. 12,000 divided by 1.6 years = 7500 miles per year. 365 days per year divided by 2 (Yaris driven every other day) = 182.5 days per year each Yaris is driven. 7500 miles divided by 182.5 = 41 mile driven every other day. 41 miles divided by 2 trips a day = 20.5 miles per trip every other day. While I know that this is a crude way to figure out average miles per trip, it is the best equation I could come up with. Driving 20.5 miles per trip in my Yaris is questionable for recharging the battery back to 100% of capability. Of course there may be a problem with the instructions on how to install the after market fog lap kit I bought from Micro Image that I am not aware of that is killing the battery. I have too much on my credit card to be able to afford to put the Yaris in the shop for a complete electrical system check. Both Yarises passed the standard electrical check when the batteries were replaced. Next year I hope to be able to afford to put one of the Yarises in the shop to have someone experenced in installing after market fog lamps to check the work I did to see if I made a mistake installing the fog lamps and/or to see if there is a error in the install instructions. |
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Did you order fog lamps? | Driver | New YARIS Purchase Forum | 27 | 11-29-2006 06:27 PM |
| Where to find Yellow capsules for fog lamps? | W.A.S.P | Cosmetic Modifications (Exterior/Interior) | 0 | 11-26-2006 01:01 AM |
