Old 09-28-2009, 06:55 PM   #12
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
I not much for throwing away a new battery. What the Yaris really needs is a larger alternator. The owners manual says that the Yaris alternator is too small to generate enough power to heat the rear window defroster. So the rear window defroster draws additional power from the battery. The owner manual warns owners not run the rear window defroster more than 20 minutes. So the Yaris does not recharge the battery very fast. So a number of short trips could leave the battery without enough power to start the Yaris.
ellenbetty is offline   Reply With Quote
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Did you order fog lamps? Driver New YARIS Purchase Forum 27 11-29-2006 06:27 PM
Where to find Yellow capsules for fog lamps? W.A.S.P Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 01:01 AM
